AppImages of v0.18 release builds
easyw-fc
Re: AppImages of v0.18 release builds
Postby easyw-fc » Sun Apr 14, 2019 7:16 pm
I have a performance issue both on 0.18 and 0.19 Appimage with one of my WBs, when loading a curve and creating Sketches.
I need to investigate it a bit to reduce the problem to the real culprit...
It shouldn't be related to Qt5 or Py3 because FC 0.18.1 just runs smoothly...
I don't have any issue in Win also within the Conda builds...
EDIT: I also don't have issue with 0.17 Appimage
here my FC details
OS: Linux Mint 19.1 (MATE/mate)
Version: 0.19.16398 (Git) AppImage
Hash: 847035cbd227d1f7554a494c3cfe5fa8942f2b7c
Python version: 3.7.1
Qt version: 5.6.2
EDIT2
I tried to create a log file after expanding AppImage as following:
FreeCAD_0.19_dev.AppImage  --appimage-extract
cd squashfs-root
./AppRun --log ./fclog.log
and I get this errors:
Gtk-Message: 21:36:43.971: Failed to load module "gail"
Gtk-Message: 21:36:43.972: Failed to load module "atk-bridge"
EDIT3
Running my scripts I get this error log:
(FreeCAD:7348): GdkPixbuf-WARNING **: 21:48:09.160: Cannot open pixbuf loader module file '/home/travis/build/FreeCAD/FreeCAD-AppImage/conda/linux/AppDir/usr/lib/gdk-pixbuf-2.0/2.10.0/loaders.cache': No such file or directory
This likely means that your installation is broken.
Try running the command
gdk-pixbuf-query-loaders > /home/travis/build/FreeCAD/FreeCAD-AppImage/conda/linux/AppDir/usr/lib/gdk-pixbuf-2.0/2.10.0/loaders.cache
to make things work again for the time being.
EDIT4
I don't get any of the above messages on FreeCAD-0.17.13541.9948ee4.glibc2.17-x86_64.AppImage
looo
Postby looo » Sun Apr 14, 2019 8:52 pm
Hmm, I am not sure if these issues have impact on performance... @easyw-fc can you test in a conda-env with python3.7?
Maybe we can change some absolute-path to relative-paths using these instructions:
https://docs.appimage.org/packaging-gui ... oded-paths
This should solve some of the reported issues.
please help with my conda-packaging efforts: https://liberapay.com/looooo/
minimalistic blog: https://looooo.github.io/mini-blog/
NormandC
Postby NormandC » Sun Apr 14, 2019 9:07 pm
EDIT3
Same error as I reported above.
easyw-fc
Postby easyw-fc » Sun Apr 14, 2019 10:09 pm
as @NormandC reported
NormandC wrote:
Sun Apr 14, 2019 2:53 pm
Confirmed on Ubuntu 18.04/GNOME.
Here's a more detailed output at launch. I also notice it takes a longer time to load the splash screen.
the performance issue could be related to the fact that during loading my script trigs many warning messages that could slow down the all process.
looo
Postby looo » Mon Apr 15, 2019 4:28 am
Ok then we should definitely try to solve this problem. So 2 things should be done in the appimage creation:
1. Browse all files and replace all occurrences of absolute paths with relative. I guess we were simple lucky to not have to deal with such problems until now.
2. Add the gtk-variable at the initialization script
As a backup solution we can still use the old toolchain.
doubters
Postby doubters » Mon Apr 15, 2019 10:02 am
I created a separate topic with a similar problem: https://forum.freecadweb.org/viewtopic.php?f=4&t=35647, but it turned out that I had to write here. Under the link you can see errors and screenshots.
looo
Postby looo » Mon Apr 15, 2019 2:54 pm
By setting the PREFIX variable in the APPRUN script the Pixbuf warning should be gone. Also the theme should look a bit better.
I made the experience that the first time running the appimage will need some time. I guess this is because matplotlib does any font-specific task. At least we have seen this already with some previous versions of the appimage.
Another problem seems to be the freecad.plot / freecad.ship libraries installed during the appimage creation. It's not possible to overwrite these modules by development packages. I guess it's better to not install these modules by default, so I will remove them for the next iteration.
doubters
Postby doubters » Mon Apr 15, 2019 4:04 pm
Tell me, what kind of variable?
looo
Postby looo » Mon Apr 15, 2019 4:13 pm
is included in the latest appimages. This one here: https://github.com/FreeCAD/FreeCAD-AppI ... 7e2c5047c3
Btw.: I don't know how to fix the failing gtk modules. I see these warnings for a long time and as this is only about GUI I normally don't care much about it. With conda I am pretty used to ugly GUI. It changes from time to time. But if it is too ugly I simple switch to a custom theme of FreeCAD.
In my eyes it's more important to fix the functionality-issues first. So it would be nice to know if there are still performance issues with the latest appimages.
easyw-fc
Postby easyw-fc » Mon Apr 15, 2019 4:48 pm
is it possible to have a direct link to download and test the latest?
