Textsymbols DIN 7184
reox
Re: Textsymbols DIN 7184
Postby reox » Mon Mar 18, 2019 9:42 am
yes, I added those, as well as the two arrows and the square symbol ;)
I noticed that there are even more modifiers listed in my technical drawing book, but I would need to look them up.
Also need to work on the visibilty of the symbols...
I do not find the "ST" symbol anywhere, and it is not listed in my book. Is this some legacy symbol?
efyx
Postby efyx » Mon Mar 18, 2019 11:02 am
I cannot start macro - why? I got information No module named PySide.QtWidgets
reox
Postby reox » Mon Mar 18, 2019 11:51 am
mhh maybe because I'm using a py3/qt5 build with pyside2?
OS: Debian GNU/Linux buster/sid
Version: 0.19.16146 (Git)
Hash: 3cf15c014bec8a7a7fa56fdf0adf1402c724d788
Python version: 3.7.3rc1
Qt version: 5.11.3
Locale: German/Austria (de_AT)
ii  libpyside2-5.11           5.11.2-3     amd64        Python 2 bindings for Qt5 (base files)
ii  libpyside2-dev            5.11.2-3     amd64        Python bindings for Qt5 (development files)
ii  libpyside2-py3-5.11       5.11.2-3     amd64        Python 3 bindings for Qt5 (base files)
ii  pyside2-tools             5.11.2-3     amd64        development tools for PySide2 (uic, rcc, lupdate)
un  python-pyside2-doc        <keine>      <keine>      (keine Beschreibung vorhanden)
ii  python-pyside2.qtcore     5.11.2-3     amd64        Python bindings for Qt5 core module (Python 2)
ii  python-pyside2.qtgui      5.11.2-3     amd64        Python bindings for Qt5 Gui module (Python 2)
ii  python-pyside2.qtopengl   5.11.2-3     amd64        Python bindings for Qt5 OpenGL module (Python 2)
ii  python-pyside2.qtwidgets  5.11.2-3     amd64        Python bindings for Qt5 Widgets module (Python 2)
ii  python-pyside2uic         5.11.2-3     all          User Interface Compiler for PySide2 (Python 2)
ii  python3-pyside2.qtcore    5.11.2-3     amd64        Python bindings for Qt5 core module (Python 3)
ii  python3-pyside2.qtgui     5.11.2-3     amd64        Python bindings for Qt5 Gui module (Python 3)
ii  python3-pyside2.qtopengl  5.11.2-3     amd64        Python bindings for Qt5 OpenGL module (Python 3)
ii  python3-pyside2.qtsvg     5.11.2-3     amd64        Python bindings for Qt5 Svg module (Python 3)
ii  python3-pyside2.qtwidgets 5.11.2-3     amd64        Python bindings for Qt5 Widgets module (Python 3)
ii  python3-pyside2uic        5.11.2-3     all          User Interface Compiler for PySide2 (Python 3)
pl7i92LCNC
Postby pl7i92LCNC » Mon Mar 18, 2019 12:31 pm
hi il get a error by utf-8 on ubuntu 18,04
is this the QT issue
and canot be solved
reox
Postby reox » Mon Mar 18, 2019 12:36 pm
and canot be solved
I would guess that is because python2... Looks like the macro needs some backwards compatibility :oops:
reox
Postby reox » Mon Mar 18, 2019 2:21 pm
Can you both test it now? I tested with freecad from debian sid and it works there now.
It should look similar to the image, but the sorting might be different in python2, as dicts behave differently.
Postby Kunda1 » Mon Mar 18, 2019 4:06 pm
Maybe unrelated: what about Welding symbols? issue #1240
reox
Postby reox » Mon Mar 18, 2019 4:15 pm
I had a quick look around, but it looks like they are not defined in unicode.
But someone created a glyph font: https://www.fontspace.com/micronus/y145 ... 90/charmap
efyx
Postby efyx » Tue Mar 19, 2019 7:12 am
It works. Thanks.
reox
Postby reox » Thu Mar 28, 2019 8:24 pm
Just for the reference as I'm skimming through all the norms right now... There are many more symbols unsolved:
ISO 14405-1 specifies some "Specification modifiers", two letters enclosed in a rounded box.
Then there are annotation signs: a number inside a hexagon
Next ISO 1101:2017 specifies even more modifiers, more than OSIfont can handle: A, C, G, N, R, X are missing
Also interesting: the theoretical exact value (idk the exact translation, in German "theoretisch exakte Maße"), a value inside a rectangle
Then there are modifiers according to ISO 5459:2013, but these should be all in the osifont or are just letters in between of [].
Wouldn't it be possible to use diacritic characters to emulate all of those?
Some of those are actually possible:
https://en.wikipedia.org/wiki/Combining ... or_Symbols
So for example writing a single letter inside a square is possible.
One possibility would be to extend osifont with the welding symbols as well as with diacritics for all those cases. But I guess that is a lot of work :/
cron
