Ticket #3915 - v0.18 Planar Image crossplatform show/hide bug
Geoplace
Postby Geoplace » Tue Mar 26, 2019 3:04 pm
Hi
I just trying FreeCAD v0.18 and I often work freecad files from 2 different machines. I having troubles with the show/hide image.
1.- Open FreeCAD v18 in OpenSuse OS.
OS: openSUSE Leap 15.0
Version: 0.18.Unknown
Python version: 3.6.5
Qt version: 5.9.4
Coin version: 3.1.3
Locale: Spanish/Spain (es_ES)
2.- Switch to Image workbench and use “Create a planar image in the 3D space”
3.- Scale the image using the formula function.
size scale.png (9.74 KiB) Viewed 1321 times
4.- Modify its placement in the X axis by 80 cm.
5.- Hit the spacebar key to hide the ImagePlane we’ve just created.
6.- Save the file and close the linux FreeCAD.
7.- Open FreeCAD v18 in Windows OS.
OS: Windows 8.1
Version: 0.18.16093 (Git)
Branch: releases/FreeCAD-0-18
Hash: 690774c0effe4fd7b8d2b5e2fb2b8c8d145e21ce
Python version: 3.6.6
Qt version: 5.6.2
Locale: Spanish/Mexico (es_MX)
8.- Open the File created before.
9.- Select the ImagePlane in the Model View TAB.
10.- Hit the spacebar (Toggle Visibility) to show the ImagePlane.
11.- The image didn’t show. And the Report View throw this message:
Report View:
Unhandled Base::Exception caught in GUIApplication::notify.
The error message is: Access violation
imageplane error1.png (85.68 KiB) Viewed 1321 times
ReportView Access Violation, The icon switch to show image but nothing shown.
imagePlane error2.png (88.42 KiB) Viewed 1321 times
ReportView Access Violation, The icon switch to hide.
Reason: Added ticket number to thread title
Geoplace
Re: v0.18 Planar Image crossplatform show/hide bug
Postby Geoplace » Tue Mar 26, 2019 3:17 pm
Update:
I've just tested the bug with Windows Only workflow
1.- Create Planar Image.
2.- The same error acceso violation.
3.- And when trying to save the file the save Access Violation Error. So I can't save the file.
ImagePlane AccessViolation.PNG (151.54 KiB) Viewed 1316 times
OS: Windows 8.1
Qt version: 5.6.2
The version 0.17 works just fine.
OS: Windows 8.1
Version: 0.17.13541 (Git)
Branch: releases/FreeCAD-0-17
Python version: 2.7.14
OCC version: 7.2.0
Syres
Postby Syres » Tue Mar 26, 2019 6:01 pm
This maybe of use : https://forum.freecadweb.org/memberlist ... le&u=12184
Even if your graphics card isn't the same type, the driver for your particular card would be the area I would recommend investigating and it's not always the latest version that gives the best result. I recently had to back out a NVidia upgrade due a side effect that meant I had to DR my box from January.
Geoplace
Postby Geoplace » Tue Mar 26, 2019 8:02 pm
The laptop I use has Intel integrated graphics, there has not been a recent upgrade the graphics driver.
This function works fine in the released v0.17 but no more in the v0.18 release candidate.
I'll will keep an eye to a newer or more stable 0.18 release to see if this bug changes.
Syres
Postby Syres » Tue Mar 26, 2019 9:05 pm
There was another report that @GeneFC managed to find a driver to make Intel Graphics work with 0.18 https://forum.freecadweb.org/viewtopic. ... 0#p280582 and yes I'm not surprised that it's fine in 0.17 but fails in 0.18 RC.
Geoplace
Postby Geoplace » Mon Apr 01, 2019 10:13 pm
Hi Syres
I downgraded fromo Intel(R) HD Graphics 520 Version: 21.20.0016.4821
to Version: 21.20.0016.4574
But no good luck. The same error is thrown.
I would try to find other driver's version to see if pure driver error o also FreeCAD componentes.
Stay tune.
Geoplace
Postby Geoplace » Tue Apr 02, 2019 3:11 pm
Hi Syres
Today I downgraded to version: 21.20.0016.4354
From year 2016 I think I there's no older driver. There's the same error:
So, What else can we do to iron out this bug??
Postby Kunda1 » Wed Apr 03, 2019 2:51 pm
Linking back to issue #3915 from this thread
Postby Kunda1 » Fri Apr 26, 2019 2:10 pm
@chrisb shall we add this to 'Known Issues' ?
Postby chrisb » Fri Apr 26, 2019 4:05 pm
Too much praise, but thank you.
Usually I wait until it happens a second time. In the other cases driver up- or downgrades helped. Should I place just a link in the drivers section?
