Text is on wrong side of dimension line
babaroga
Location: Banja Luka, Republic of Srpska, Bosnia and Herzegovina
Postby babaroga » Thu Mar 28, 2019 8:37 pm
Last update with preferred number format was something I was waiting for long time. Thank you!
However I run to another problem. On my test object, dimension text on two dimensions on the right side is on wrong side of dimension line.
It seems like if line is angled on more than 135° compared to x axis, dimension number is placed under dimension line. With horizontal and vertical dimensions it seems to work OK.
Similar thing happens with angle dimensioning. Note 15° dimension on right half of model.
Test model is in attachment.
Should I report Bug?
OS: Manjaro Linux
Version: 0.19.16266 (Git)
Build type: Unknown
Hash: ea034215937502bcff3cfd447903977f0656856f
Python version: 3.7.2
Qt version: 5.12.1
Tech draw test.FCStd
(21.14 KiB) Downloaded 11 times
wandererfan
Re: Text is on wrong side of dimension line
Postby wandererfan » Fri Mar 29, 2019 1:13 pm
Yes, please. When the dimension line is close to 45* the code sometimes gets confused. Not sure what's going on with the angle on the wrong side.
wandererfan
Postby wandererfan » Tue Apr 02, 2019 12:12 pm
This should be fixed by git commit a7e82e8612.
babaroga
Postby babaroga » Tue Apr 02, 2019 4:38 pm
It seems OK now. Thanks!
