Engine running with A2Plus
dcapeletti
Postby dcapeletti » Wed Apr 10, 2019 7:56 am
I just saw this example using Assembly 4. It's an engine assembled and running.
https://forum.freecadweb.org/viewtopic. ... 06#p293179
Since the design files are available in the ASM 4 repository, it wouldn't take too long to do the assembly. You only need to design the crankshaft, make an assembly and make a script to move the crankshaft which moves the whole assembly.
Is anyone encouraged to do so?
I'll try it in my free time. I listen to suggestions or recommendations.
Thanks
dcapeletti
Re: Engine running with A2Plus
Postby dcapeletti » Mon May 20, 2019 11:33 pm
I made the engine and the assembly with A2Plus. The camshaft is still to be finished. You can see the GIF to see the animation in operation.
https://gitlab.com/dcapeletti/ejercicio ... A2Plus.gif
Repository with all parts
https://gitlab.com/dcapeletti/ejercicio ... %20tiempos
roerich_64
Postby roerich_64 » Mon May 20, 2019 11:47 pm
Thumbs up! Awesome :-)
dcapeletti
Postby dcapeletti » Tue May 21, 2019 10:19 am
Thank you very much.
What I'm trying to do is make the animation run a little faster. In a thread I was recommended to deactivate the following lines https://forum.freecadweb.org/viewtopic. ... on#p264362 and it has worked, but it is still a bit slow.
My animation code is as follows https://gitlab.com/dcapeletti/ejercicio ... /README.md
Greetings
kbwbe
Postby kbwbe » Tue May 21, 2019 3:56 pm
Hi Diego,
good work ! :D
A2plus is not really a simulation WB, as it's solver is python based ATM. Therefore it can not compare with solvers written in C.
Perhaps this will come in future.
Greetings, Klaus
KBWBE
latest release: v0.4.43a, installable via FreeCAD's addon manager
