Default format - small fix
babaroga
Location: Banja Luka, Republic of Srpska, Bosnia and Herzegovina
Postby babaroga » Sun Apr 14, 2019 10:04 pm
After introduction of default format in TD I realised that diameter and radius symbol on dimensions were overriden by deafault format entered in preferences dialog. So if you enter anything as default format, diameter and radius symbol is missing on dimensions.
This is my small fix for this issue. @WandererFan can you please test it and consider change it since I am not Github guru?
This code in DrawViewDimension.cpp somewhere end of the file
std::string DrawViewDimension::getDefaultFormatSpec() const
    Base::Reference<ParameterGrp> hGrp = App::GetApplication().GetUserParameter()
                                         .GetGroup("BaseApp")->GetGroup("Preferences")->GetGroup("Mod/TechDraw/Dimensions");
    std::string prefFormat = hGrp->GetASCII("formatSpec","");
    QString formatSpec;
    if (prefFormat.empty()) {
        QString format1 = Base::Tools::fromStdString("%.");
        QString format2 = Base::Tools::fromStdString("f");
        int precision;
        if (useDecimals()) {
            precision = Base::UnitsApi::getDecimals();
        } else {
            precision = hGrp->GetInt("AltDecimals", 2);
        QString formatPrecision = QString::number(precision);
        std::string prefix = getPrefix();
        QString qPrefix;
        if (!prefix.empty()) {
            qPrefix = QString::fromUtf8(prefix.data(),prefix.size());
        formatSpec = qPrefix + format1 + formatPrecision + format2;
    } else {
        return prefFormat;
    return Base::Tools::toStdString(formatSpec);
is to be replaced by :
    QString formatSpec;
    QString qPrefix; //Move it here
        int precision;
        } else {
        //QString qPrefix;
    } else {
        //return prefFormat;
        formatSpec = qPrefix + QString::fromStdString(prefFormat);
wandererfan
Re: Default format - small fix
Postby wandererfan » Tue Apr 16, 2019 11:35 am
Thanks. Desk check looks good. My devl environment is crowded right now, might take a few days to get to this.
If you can read and modify code, you can do Github. Somewhere in the forum there are step by step instructions. I'll see if I can find them.
wandererfan
Postby wandererfan » Tue Apr 16, 2019 11:54 am
babaroga
Postby babaroga » Tue Apr 16, 2019 12:08 pm
OK, I will study it :oops:
THX
babaroga
Postby babaroga » Wed Apr 17, 2019 10:27 am
So, I did my first Pull request. It says checks are OK.
What now? Is there something else I should do?
wandererfan
Postby wandererfan » Wed Apr 17, 2019 12:34 pm
Awesome! Your change has been merged into master branch. You are now a FreeCAD developer!
Find another bug to fix? :D
babaroga
Postby babaroga » Wed Apr 17, 2019 1:11 pm
Yeeeeah,
I will drink a beer in that name... :D
Of course, there is one more I am working on. If "Show unit of measure" is ticked off in preferences, " ° " degree sign is missing on angular measures.
wandererfan
Postby wandererfan » Wed Apr 17, 2019 1:17 pm
Lots more fixes to be made. I may have to figure our how to send you a case of beer.
