Issue with padding a sketch
AliHatukai
Postby AliHatukai » Wed Apr 17, 2019 12:43 pm
Hi all :)
I have this small issue with me trying to pad a sketch in part design, But before that i want to ask sometihng..
What's the difference between "Pad" in part design workbench or "Extrude" in part workbench ?
And not to the issue itself. I have this simple sketch (That took me forever to do i must admit..) that when i try to extrude
it fails, and when i try to pad it for some strange reason it cuts part of the sketch off..
something it writes in the report view is
Part::Extrusion: Links go out of the allowed scope
Exception (Wed Apr 17 15:48:28 2019): Wire is not closed.
any help ?
thanks.
Mold for ASTM D638.FCStd
(12.12 KiB) Downloaded 2 times
HarryGeier
Re: Issue with padding a sketch
Postby HarryGeier » Wed Apr 17, 2019 12:55 pm
Hello Ali
the difference is :
A PAD creates a parametric FEATURE ( OCC based ) in Part Design. I can be based on sketch or on a face.
An Extrusion creates an CSG Object based on any shape.
PAD should be used in Part Design based projects . Extrusions should be used in non Part Design based projects and can be used as base features for beeing further modelled in part Design .
Mixing both is possible but sometimes tricky and error prone. Thus ist should be used by experienced users.
Your sketch problem: The line at the right end ( short vertical ) exists 2 times.. Delete one of them , then it works
AliHatukai
Postby AliHatukai » Wed Apr 17, 2019 1:04 pm
Hello Ali
the difference is :
Thanks for your help!
I fixed the issue by the way. Found the spot where the lines didnt connect and now it works fine.
Thanks!
HarryGeier
Postby HarryGeier » Wed Apr 17, 2019 1:08 pm
Fine, see my answer edited...
AliHatukai
Postby AliHatukai » Wed Apr 17, 2019 1:17 pm
I did exactly what you told me to do and it works. thanks!
bejant
Postby bejant » Wed Apr 17, 2019 2:41 pm
Hi Ali, and welcome!
A few more differences for FreeCAD version 0.17 and newer:
  • Pad must be inside a Body container.
    • Not so with Extrude.
  • The result of Pad must be one solid.
    • The result of Extrude can be separate geometries.
    • The result of Extrude doesn't have to be solid.
