ARCH Section and Techdraw ArchView not clipping
elsordo
Postby elsordo » Tue Apr 23, 2019 12:33 am
How does one go about clipping an ARCH Section within a Techdraw ArchView.
I created an ARCH Section that includes a lot of objects but with a height and length that effectually clips the included objects.
When I add the ARCH section to a Techdraw ArchView, the height and length properties of the Arch Section are ignored and the ArchView displays the entirety of the objects included in the Arch Section.
Is this expected behavior? I thought that that the Arch Section also functioned as a "clipping" mechanism.
-David
My Freecad installation information is
OS: Ubuntu 18.04.2 LTS
Version: 0.18.1.
Python version: 3.6.7
Qt version: 5.9.5
vocx
Re: ARCH Section and Techdraw ArchView not clipping
Postby vocx » Tue Apr 23, 2019 12:52 am
elsordo wrote: Tue Apr 23, 2019 12:33 am How does one go about clipping an ARCH Section within a Techdraw ArchView.
You should provide a picture as your question isn't very clear.
Which properties? The Display Height, and Display Length? These properties of the Arch SectionPlane only control the appearance of the plane in the 3D viewport, but do not affect the way the objects are seen by the plane. A plane is infinite in area, so it will see everything in the entire model, as long as it is included in its Objects property (double click on the plane in the tree view).
Objects have two types of properties, "View properties", and "Data properties". View properties only affect how the object is shown to you in the 3D viewport, but they don't control the "contents" of the actual object. Only the data properties will determine how the object is interacting with other objects in the document.
elsordo
Postby elsordo » Tue Apr 23, 2019 3:20 am
vocx,
I have attached an image showing the 3d model and an image showing the techdraw page.
As you can see, the techdraw image is show more objects that what are selected by the ARCH Section view port.
-David
Screenshot from 2019-04-22 23-12-40.png (283.08 KiB) Viewed 555 times
Screenshot from 2019-04-22 23-09-43.png (288.79 KiB) Viewed 555 times
vocx
Postby vocx » Tue Apr 23, 2019 4:05 am
elsordo wrote: Tue Apr 23, 2019 3:20 am As you can see, the techdraw image is show more objects that what are selected by the ARCH Section view port.
Your image doesn't show what is "selected" by the Arch SectionPlane.
Double click on the Section object in the three view, or see what is in the Objects property under the Data tab. If all elements in the model are part of the Objects property, then all those elements will be shown in the TechDraw page.
An Arch SectionPlane is an infinite plane, that is, it extends to the infinite in both directions X and Z. It is not a camera view with a limited field of view, like in Blender.
elsordo
Postby elsordo » Tue Apr 23, 2019 8:17 pm
I have attached a picture of the dialog box for editing an ARCH Section. As you can see, it contains most of the model. I tried to include the model (FCSTD file) but it is too large.
However, you did answer the question as to why clipping does not occur -
So, I have the following questions:
1. Is there a way to accomplish clipping? I was hoping to avoid presentation-dependent-modeling.
2. What is the purpose of the "Display Height", "Display Length", "Cut Distance", "Cut Margin", and "Cut View" properties of the Arch Section view tab?
-David
Screenshot from 2019-04-23 16-03-53.png (258 KiB) Viewed 521 times
vocx
Postby vocx » Tue Apr 23, 2019 11:20 pm
elsordo wrote: Tue Apr 23, 2019 8:17 pm 1. Is there a way to accomplish clipping? I was hoping to avoid presentation-dependent-modeling.
Arch objects are solid shapes, so they can be selected and TechDraw NewView can be used on them. Then TechDraw NewSection and TechDraw Clip can be used on the created view.
As I said, those are properties that affect only the way the plane is presented in the 3D viewport. They don't affect the contents.
Height and Length indicate how big the plane should be seen; the plane is always infinite in size, but it has to be displayed at a certain finite size.
Cut Distance currently doesn't do anything (programmer's fault).
Cut View indicates if the objects that cross the plane are cut by that plane. You need an Arch SectionPlane that is crossing through an object to see its effects. Cut Margin indicates the normal distance from the plane, from which the cut is actually made. It is a small value, 1 mm, indicating that the objects are cut 1 mm away from the plane, basically at the position of the plane.
vocx
Postby vocx » Mon May 06, 2019 11:11 pm
wandererfan
Postby wandererfan » Tue May 07, 2019 12:11 am
I haven't tried it yet, but you could try putting the ArchView inside a TechDraw_Clip.
