(Bug) Floor container don't keep objects hidden
Geoplace
Postby Geoplace » Tue Apr 23, 2019 4:50 pm
Floor Container has an impact of not maintaining the desired object visibility (hide) when you edit other objects inside it, the hided ones are shown again.
Also when you save the file with the rectangle hidden and when re-open it again it will show everything. (Don’t save the hide status of the children objects)
1.-Choose the Arch workbench.
2.-Draw a line (one or more) and a rectangle (its face property is true)
3.-Create a floor object.
4.-Drag and Drop the line and rectangle inside the floor object.
5.-Select the Rectangle object and hit spacebar key (to toggle visibility) hide it.
rectangle hidden.png (67.04 KiB) Viewed 285 times
6.-Draw a new line or trim extend one existent. Or change its length and clic recompute button (F5).
7.-The rectangle show again without request. (If it is the base of a slab, the slab will show)
line modified and rectangle shown.png (175.36 KiB) Viewed 285 times
When all the elements are outside the Floor Container you can modify the line elements and the visibility of the rectangle stays as needed (hide)
Here is a sample file where you just need to do step 5 and 6 to view the bug.
Hide Arch Shown unexpected Bug.FCStd
(13.94 KiB) Downloaded 10 times
Please confirm if it is a bug to file its report.
What do you think @yorik?
Tested with:
OS: Windows 8.1
Version: 0.18.16110 (Git)
Branch: (HEAD detached at upstream/releases/FreeCAD-0-18)
Python version: 3.6.6
Qt version: 5.6.2
OS: Windows 8.1
Version: 0.19.16502 (Git)
Hash: 06962535fa9ff348acca1b893cc4239908fb8bae
Qt version: 5.6.2
yorik
Site Admin
Re: (Bug) Floor container don't keep objects hidden
Postby yorik » Thu Apr 25, 2019 7:12 pm
Yes I have seen this behaviour too, BuildingPart objects constantly turn their children on. But so far couldn't find the cause. It is likely because of the Group extension, but couldn't find any further clue...
Geoplace
Postby Geoplace » Mon Apr 29, 2019 2:28 pm
Yes I have seen this behavior too, BuildingPart objects constantly turn their children on. But so far couldn't find the cause. It is likely because of the Group extension, but couldn't find any further clue...
Is ok to file a bug report?
So there could get some interdisciplinary help.
Regards.
yorik
Site Admin
Postby yorik » Tue Apr 30, 2019 1:53 pm
Yes, sure!
yorik
Site Admin
Postby yorik » Thu May 02, 2019 5:04 pm
Thanks!
