Path Pocket Shape: 4th-axis Integration
Russ4262
Re: Path Pocket Shape: 4th-axis Integration
Postby Russ4262 » Tue May 28, 2019 12:48 pm
Morning J.
I'm loading up the model now to attempt reproduction of the behavior. I think the problem may be the same as presented in another recent topic, Bug in Path/Pocket 0.19. I'll take a look.
RatonLaveur wrote:
Tue May 28, 2019 12:12 pm
Hello gents,
A little bit more feedback. Finally confident that I could use the 4th axis integration for actual testing in my 3+2 machine, I prepare a comparatively simple model: a square tip to be cut from square rod.
Fooling around with the options, the use of the Path Pocket shapes moves the model relative to the stock in a funny way. I see no reason why path pocket should move the work piece model that way.
If the problem is has the same root cause, I have a solution already coded, just not isolated and uploaded.
Russ
Russ4262
Postby Russ4262 » Tue May 28, 2019 1:08 pm
J.,
I was able to reproduce the error. Preliminary results suggest same issue as topic mentioned in previous post.
Hello gents, ...
I'll compare the causes to determine if the causes are indeed one and the same. I'm hopeful they are because I have already been working on the solution.
Russ
RatonLaveur
Postby RatonLaveur » Tue May 28, 2019 1:17 pm
Hi Russ, sorry if that was a repost. reading the topic you pointed at yields the same conclusion. I don't believe in coincidences. Thanks for looking into it you rock.
Russ4262
Postby Russ4262 » Sat Jun 01, 2019 5:33 am
Morning All,
I just updated the PathPocketShape and PathAreaOp scripts in the initial post to version 1k-testing. The updates should correct the random repositioning/jumping of the Job model when using Path Pocket operation. The script now creates an additional clone per axis_angle rotation for basis of rotational pockets, then destroys the temp clone used. You will need to re-create Path_Shape operations because the "Use Rotation" property is renamed "Enable Rotation" to prepare for UI integration.
Thanks for the feedback.
Russell
RatonLaveur
Postby RatonLaveur » Sat Jun 01, 2019 4:17 pm
Thank you russ, can't wait to play with it!
Russ4262
Postby Russ4262 » Tue Jun 04, 2019 2:46 am
The fix for this issue is included in PR #2231. Please review and provide feedback here or as comments on the PR page.
I'm thankful for the feedback and your enjoyment. Oddly, I don't even have a 4th-axis machine. Furthermore, the machine I have partial ownership of is over at my dad's house. So, I just develop for the 4th-axis.
Thanks J.,
Russell
RatonLaveur
Postby RatonLaveur » Tue Jun 04, 2019 7:16 am
Hey Russ,
Been playing around with the pocketing and profiling ops on the square tip file attached.
Good news: no jumping around of the model anymore! that's pretty neat. I've tried varied combination of parameters and it seems solved for now, until someone smarter than me complains about it :)
The op paths are, however, not really well placed. I've systematically cycled through the B axis override/reverse direction/reverse angle parameters to eliminate them as possibilities for the mismatch. Something tells me it has something to do with the clones.
I've had one bug so far where a clone appeared and stayed, which I assume to be one of the operations being interrupted mid script. But I couldn't reproduce it.
EDIT: system info
OS: Windows 7
Version: 0.18.16093 (Git)
Branch: releases/FreeCAD-0-18
Hash: 690774c0effe4fd7b8d2b5e2fb2b8c8d145e21ce
Python version: 2.7.14
OCC version: 7.2.0
Locale: French/Switzerland (fr_CH)
I favor this build because it works well and i use it to work, but it is still allowing me to experiment with the new ops thanks to the community's work.
TipCutting.FCStd
(36.77 KiB) Downloaded 11 times
Russ4262
Postby Russ4262 » Tue Jun 04, 2019 2:00 pm
I will take a look. I placed a hold on the PR until we figure this out.
Also, what is your FreeCAD system info? Any changes? Please update your previous post with that info.
Thanks for all the feedback, Sir.
Russ
Erich Schulz
Postby Erich Schulz » Thu Jun 06, 2019 4:56 am
awwwww Russ - book your flights to Brisbane and you can help me play with mine when it arrives by boat from China!
Erich Schulz
Postby Erich Schulz » Thu Jun 06, 2019 6:14 am
two things:
I'm thinking this thread could be well captured in the wiki together with the facing operation, so I've integrated it roughly over here: https://www.freecadweb.org/wiki/Fourth_Axis
secondly - these pictures are making me dizzy - it looks like these are 5 axis operations - is that correct or am I missing something???
