(Problem) PySide2.QtUiTools and PySide2.QtXml are dependencies of CfdOF but not of FreeCAD
Moderator: oliveroxtoby
vocx
Postby vocx » Thu Apr 25, 2019 10:13 pm
I've been testing the CfdOF examples in openSim.
Everything seems to go well, however, when I try to input a CFD boundary condition an error occurs.
  File "/home/vocx/.FreeCAD/Mod/CfdOF/_ViewProviderCfdFluidBoundary.py", line 94, in setEdit
    import _TaskPanelCfdFluidBoundary
  File "/home/vocx/.FreeCAD/Mod/CfdOF/_TaskPanelCfdFluidBoundary.py", line 37, in <module>
    import CfdFaceSelectWidget
  File "/home/vocx/.FreeCAD/Mod/CfdOF/CfdFaceSelectWidget.py", line 47, in <module>
    from PySide import QtUiTools
  File "/usr/share/freecad/Ext/PySide/QtUiTools.py", line 1, in <module>
    from PySide2.QtUiTools import *
<class 'ModuleNotFoundError'>: No module named 'PySide2.QtUiTools'
It complains about missing PySide2.QtUiTools, so I install this package.
sudo apt install python3-pyside2.qtuitools
Then I try again to add the boundary conditions and it fails again.
<class 'ImportError'>: could not import module 'PySide2.QtXml'
It complains about missing PySide2.QtXml, so I install this package as well.
sudo apt install python3-pyside2.qtxml
With the two dependencies satisfied, CfdOF finally shows the task panel to set up the boundary conditions.
I have FreeCAD installed from the freecad-stable repository, but it seems the two packages mentioned aren't required dependencies, so they aren't automatically pulled by FreeCAD. Either the freecad package should be updated with this information, or CfdOF should check these two packages as dependencies together with PySide2.
apt-cache depends freecad-python3
freecad-python3
  Depends: freecad-common
  Depends: freecad-runtime
  Depends: python3-matplotlib
  Depends: python3-pivy
  Depends: python3-pyside2.qtcore
  Depends: python3-pyside2.qtgui
  Depends: python3-pyside2.qtsvg
  Depends: python3-pyside2.qtwidgets
  Depends: python3-pyside2uic
  Depends: libfreecad-python3-0.18
  Depends: libc6
  Depends: libgcc1
  Depends: libpython3.6
  Depends: libqt5core5a
  Depends: libqt5widgets5
  Depends: libstdc++6
  Conflicts: <libfreecad-python2-0.17>
  Breaks: <libfreecad-python2-0.17>
  Replaces: <libfreecad-python2-0.17>
Another option is to avoid using PySide2.QtUiTools and PySide2.QtXml. How much are they used in CfdOF?
OS: Ubuntu 18.04.2 LTS
Version: 0.18.1.
Python version: 3.6.7
Qt version: 5.9.5
kkremitzki
Re: (Problem) PySide2.QtUiTools and PySide2.QtXml are dependencies of CfdOF but not of FreeCAD
Postby kkremitzki » Thu Apr 25, 2019 10:32 pm
This is a packaging bug that has been mentioned to me a few times before but fell through the cracks, gonna fix it at salsa.debian.org/science-team/freecad and then have updates flow from there.
vocx
Postby vocx » Thu Apr 25, 2019 10:54 pm
Great.
