QT-Dialog convert to python
Chri1
Postby Chri1 » Sun Apr 28, 2019 4:25 pm
Hello
I made a dialog in QT-Creator and tried to convert it for Win7 like in www.freecadweb.org/wiki/Dialog_creation :
"@C:\Python27\python" "C:\Python27\Lib\site-packages\PySide\scripts\uic.py" %1.ui > %1.py"
But on the whole PC I cannot find uic.py and also no folder Python27
(QT is installed and of course FreeCad)
Where can I get it / What is to do?
Thanks for your help
Chr1
vocx
Re: QT-Dialog convert to python
Postby vocx » Mon Apr 29, 2019 2:59 am
How experienced are you at using Python, Qt, compiling from source, and software development in general?
That page is pretty old, so the information is outdated. The last major change, that was not about typos and translations, occurred in 2016. Since then FreeCAD has transitioned to using Qt5 instead of Qt4, and also prefers Python 3 rather than Python 2.
The Dialog creation topic is intended for power users or developers, so more experience with programming is assumed by the reader. You can probably find yourself what needs to be changed to get the dialog working, but as I said, you need to have more experience with Qt, and going online to read the reference documentation and find answers.
Unfortunately, the wiki documentation intended for developers is quite outdated. Until it is brought up to date, you have to fend for yourself. I suggest you take a look at the actual source code of FreeCAD (https://github.com/FreeCAD/FreeCAD) and try to see how the workbenches do what they do. You should visit macros recipes and external workbenches, as they may show you how to produce the dialogs that you want. If you use a macro, look at its source code, copy it, and base your own code on that.
mario52
Postby mario52 » Mon Apr 29, 2019 4:21 pm
hi
you must install Python27 in "C:\Python27" and pyQt for use this .bat (now PySide is used)
i have install Python 3.6 and PyQt5 for the actual FC and always error error with pyuic.py
i tray with pyuic5.exe (C:\Python36\Scripts) i use
@"C:/Python36/Scripts/pyuic5.exe" %1.ui > %1.py
and work fine but more light just the class Ui_MainWindow(object) without "démarrage"
(i upgrade the wiki later)
mario
Maybe you need a special feature, go into Macros_recipes and Code_snippets, Topological_data_scripting, Dialog creation. My macros on Gist.github.
Chri1
Postby Chri1 » Mon May 06, 2019 6:41 pm
Hi
Hi
Tried many versions of phython, but finaly it worked like this – thanks Mario:
I installed Python:
https://www.python.org/ftp/python/3.6.8 ... -amd64.exe
and from cmd:
pip3 install PyQt5-sip
pip3 install PyQt5
then Cpyuic5.exe bkneu.ui bkneu.py worked and I mad a .bat:
@" C:\Users\...\Scripts\pyuic5.exe" %1.ui > %1.py
But now I have the problem to run the dialog:
from PySide import QtGui
import bkneu
d = QtGui.QWidget()
d.ui = bkneu.Ui_Dialog()
d.ui.setupUi(d)  -> Makes Error
d.show()
Error:
QLabel(parent: QWidget = None, flags: Union[Qt.WindowFlags, Qt.WindowType] = Qt.WindowFlags()): argument 1 has unexpected type 'PySide2.QtWidgets.QWidget'
QLabel(str, parent: QWidget = None, flags: Union[Qt.WindowFlags, Qt.WindowType] = Qt.WindowFlags()): argument 1 has unexpected type 'PySide2.QtWidgets.QWidget'
bkneu.py:
from PyQt5 import QtCore, QtGui, QtWidgets
class Ui_Dialog(object):
    def setupUi(self, Dialog):
        Dialog.setObjectName("Dialog")
        Dialog.resize(400, 262)
        Dialog.setStyleSheet("background-color: rgb(206, 220, 233);")
        self.label = QtWidgets.QLabel(Dialog)   -> Here seems to be the error
What is now wrong?
Chri1
mario52
Postby mario52 » Tue May 07, 2019 8:55 am
hi
and this (single)
# -*- coding: utf-8 -*-
#import bkneu
#from PyQt5 import QtCore, QtGui, QtWidgets
# FreeCAD use PySide and not PyQt5
import PySide
from PySide import QtGui ,QtCore
from PySide.QtGui import *
from PySide.QtCore import *
        self.window = MainWindow ## adding
#        self.label = QtWidgets.QLabel(Dialog)#  -> Here seems to be the error
        self.label = QtGui.QLabel(Dialog)     #
        self.label.setText("tyty")
        self.label.setGeometry(QtCore.QRect(200, 100, 50, 20))
        ## adding begin
        self.PB_1_Quit = QtGui.QPushButton(Dialog)
        self.PB_1_Quit.setGeometry(QtCore.QRect(150, 200, 91, 28))
        self.PB_1_Quit.setText("Quit")
        self.PB_1_Quit.clicked.connect(self.on_PB_1_Quit) # connection to "on_PB_1_Quit"
    def on_PB_1_Quit(self):                               # "on_PB_1_Quit"
        App.Console.PrintMessage(str("FreeCAD the Best")+"\n")
        self.window.hide()
        ## adding end
#d = QtGui.QtWidgets()
#d.ui = bkneu.Ui_Dialog()
#d.ui.setupUi(d)# Makes Error
#d.show()
MainWindow = QtGui.QMainWindow()
ui = Ui_Dialog()
ui.setupUi(MainWindow)
MainWindow.show()
mario
Chri1
Postby Chri1 » Thu May 09, 2019 2:16 pm
Hi
It works!
# Form implementation generated from reading ui file 'bkneu.ui'
# Created by: PyQt5 UI code generator 5.12.1
# WARNING! All changes made in this file will be lost!
import PySide
from PySide2.QtWidgets import QApplication, QDialog, QLineEdit, QPushButton
        QtWidgets = PySide.QtGui
        self.label.setGeometry(QtCore.QRect(30, 10, 151, 16))
        font = QtGui.QFont()
        font.setPointSize(12)
The important Thing was: QtWidgets = PySide.QtGui
And start from FreeCad-PythonConsole:
import PySide
import bkneu
MainWindow.show()
Probably not all lines are really necessary …
Chri1
Chri1
Postby Chri1 » Fri May 17, 2019 9:09 am
Additional.
After some try and error I added this Code:
class doit():
   def __init__(self):
       self.d = QQtGui.QMainWindow()
       self.d.ui = bkneu.Ui_Dialog()
       self.d.ui.setupUi(self.d)
       self.d.show()
And now it works also with: bkneu.doit()
Chr1
Jee-Bee
Postby Jee-Bee » Fri May 17, 2019 9:21 am
class doit():
   def __init__(self):
       self.d = QtGui.QMainWindow()
       self.d.show()
you have 2 Q's in Qt
