[Solved]Black screen by starting first document
BBI_home
Postby BBI_home » Thu May 02, 2019 5:56 pm
Today I started my first experience with FreeCAD and after installing the software without any problems and after watching the FreeCad 0.18 Introduction on YouTube, I was convinced to be able to have a fluent start.
However I'm struggling with a black screen direct after CTR+N.
Also after a new installation, checking my disk space etcetera, so I need your input.
Looking forward to hear from you
Version: 0.18.16110 (Git)
Branch: (HEAD detached at upstream/releases/FreeCAD-0-18)
Python version: 3.6.6
Qt version: 5.6.2
Re: Black screen by starting first document
Postby chrisb » Thu May 02, 2019 10:08 pm
I guess it has something to do with your graphics card driver, see here for more information: https://forum.freecadweb.org/viewtopic.php?f=3&t=30573.
BBI_home
Postby BBI_home » Fri May 03, 2019 1:49 pm
I'm not sure.
Version .17 is still installed on my pcas well and this is running fine without any problems.
So to me it is 100% related to .18. I'm not aware of the details behind the scene.
I'm able to open the menu structure by clicking blind on a suspected area.
FreeCad error.png (24.03 KiB) Viewed 1773 times
Site Admin
Postby wmayer » Fri May 03, 2019 3:43 pm
See here what has changed behind the scene and possibly a workaround: https://forum.freecadweb.org/viewtopic. ... 46#p305546
Unfortunately, we don't have much control over what Qt does with OpenGL internally.
Btw, this reminds at a similar issue on Win10 I have seen some months ago with Qt5.12. A workaround was to set
Qt::AA_UseDesktopOpenGL
in the source code or alternatively set the environment variable QT_OPENGL to desktop.
BBI_home
Postby BBI_home » Sat May 04, 2019 6:47 pm
A simple solution was to buy a modern video card, in my case a MSI GeForce GT 710 1GB, for less then € 50,00
sukuwc
Re: [Solved]Black screen by starting first document
Postby sukuwc » Thu May 09, 2019 7:19 pm
When I downloaded the latest stable release (0.18 - 16110) the same black screen bug happened to me. I am very surprised because 0.18.15969 from the nightly builds worked flawlessly for 2 months or so on the same computer. This makes me doubt that Qt5 causes the issue... I attached screenshot of the two versions running at the same time. (Triple monitor setup makes screenshots weird)
I can use the older build for now but it worries me that I wont be able to upgrade if this issue is not addressed...
triplus
Postby triplus » Fri May 10, 2019 1:41 pm
If you click on "Copy to clipboard" button and paste the result in text editor. What does the "Qt version" say for each build?
P.S. But it is interesting, as i wouldn't expect anything beyond the viewport to have such issues. What happens if you close the viewport (Ctrl + W)? Any difference?
sukuwc
Postby sukuwc » Fri May 10, 2019 2:23 pm
You are right, it is different Qt version, I just automatically assumed that changing Qt was a big thing and it happened from 0.17 to 0.18 but I was wrong. Anyways, is there a way to use the newer builds with the older Qt versions?
Working:
OS: Windows 7
Version: 0.18.15969 (Git)
Hash: 4765b7e2fe6d3609e9fbf3e3eb6648d7af1dd526
Python version: 2.7.14
OCC version: 7.2.0
Not Working:
OS: Windows 7
Qt version: 5.6.2
triplus
Postby triplus » Fri May 10, 2019 2:49 pm
I took a quick look and on releases page:
https://github.com/FreeCAD/FreeCAD/releases/
It looks like there are still Py2/Qt4 builds available for Windows for now. At some point in the future likely only Py3/Qt5 builds will be made available. Maybe newer versions of Qt 5 used in binaries will improve things.
sgrogan
Postby sgrogan » Fri May 10, 2019 8:36 pm
In addition to what triplus has said, there is also a 0.19_pre https://github.com/FreeCAD/FreeCAD/rele ... g/0.19_pre LP_12.1.2 build that uses QT5.12.1
