[SOLVED] Error in exporting drawing as autodesk .dxf in freeCAD 0.18
Martin0707
Postby Martin0707 » Tue May 07, 2019 2:19 pm
An export of a drawing to an autodesk .dxf file is not working in FreeCAD 0.18 (windows 10 pc). It results in an error "invalid syntax (dxfReader.py, line 88). I have read somewhere that it might be a non-compatible phyton script?!? Will it be fixed in an update or in version 0.19? In version 0.17 it still works fine, on the same pc.
Export autodesk DXF (2D) step 1 (Freecad 0.18)
export autodesk DXF (2D) step 1.JPG (62.6 KiB) Viewed 1298 times
Export autodesk DXF (2D) step 2 (Freecad 0.18)
export autodesk DXF (2D) step 2.JPG (18.96 KiB) Viewed 1298 times
yorik
Site Admin
Re: Error in exporting drawing as autodesk .dxf in freeCAD 0.18
Postby yorik » Tue May 07, 2019 3:03 pm
This is strange... Could you try this in the python console in FreeCAD (menu Views -> Panels -> Python console):
import dxfReader
And paste here the error message that appears? It should give us more info...
Martin0707
Postby Martin0707 » Tue May 07, 2019 3:09 pm
import dxfReader
Thanks for your prompt reply. The message is:
>>> import dxfReader
ModuleNotFoundError: No module named 'dxfReader'
Postby chrisb » Tue May 07, 2019 5:11 pm
For console output it is best to put it in code tags </>. Makes it easier to identify and keeps indentations.
I have done so with your post.
easyw-fc
Postby easyw-fc » Tue May 07, 2019 5:23 pm
It seems the legacy dxf lib is not installed
Martin0707
Postby Martin0707 » Wed May 08, 2019 8:37 am
Can I install the legacy dxf lib myself somehow (or change the path pointer), or should it be done by the package installer. The legacy driver is probably already on my pc somewhere, since freeCAD 0.17 works fine with the export to .dxf function on the same pc.
easyw-fc
Postby easyw-fc » Wed May 08, 2019 8:46 am
for FC0.18 you need the latest dxf-library
it can be installed through the Addon Manager
Martin0707
Postby Martin0707 » Wed May 08, 2019 9:08 am
Thank you very much.
This was exactly what I needed. It works now. Can I give kudo`s somehow?
I'm a big fan of FreeCAD and the community!
Martin
UR_
Postby UR_ » Wed May 08, 2019 9:46 am
Please note there is a preference setting concerning this behavior ;)
Annotation 2019-05-08 113627.png (83.9 KiB) Viewed 1209 times
easyw-fc
Postby easyw-fc » Wed May 08, 2019 10:22 am
I'm not sure this is updating if the lib already exists... at least on my installation didn't do it.
You are welcome.
Just edit the title of the first most adding [SOLVED] at the beginning.
