Interrupt macro for userinput point
Chri1
Postby Chri1 » Fri May 10, 2019 2:53 pm
Hi
I want a macro / dialog be interrupted to allow the user to specify a point by pointing with the mouse.
I know "Observing mouse events in the 3D viewer via Python" but I want the snaps of existing objects to be caught.
(In AutoCAD/Lisp it would be getpoint)
Thanks for help
Chri1
Joel_graff
Re: Interrupt macro for userinput point
Postby Joel_graff » Sun May 12, 2019 10:59 am
I've never worked with snapping in Python, so I know nothing about it, I'm afraid.
However, snapping is managed in DraftSnap.py:
https://github.com/FreeCAD/FreeCAD/blob ... aftSnap.py
You might want to look at the source code there to get a feel for how it works. You can play with those functions from the FreeCAD console by importing DraftSnap in the console, then calling functions.
Chris_G
Postby Chris_G » Sun May 12, 2019 12:08 pm
A selection observer should be good for that.
Copy/paste this in the python console and pick some objects in the 3D view to test.
Uncomment last line to remove observer.
class my_selection_observer:
    """Selection observer"""
    def __init__(self):
        self.selection = []
    def addSelection(self,doc,obj,sub,pnt):
        self.selection.append(Gui.Selection.getSelectionObject(doc,obj,sub,pnt))
        print("%s.%s.%s picked at point %s"%(doc, obj, sub, pnt))
    def removeSelection(self,doc,obj,sub):
        self.selection.remove(Gui.Selection.getSelectionObject(doc,obj,sub))
    def clearSelection(self,doc):
        self.Selection = []
obs = my_selection_observer()
FreeCADGui.Selection.addObserver(obs)
#FreeCADGui.Selection.removeObserver(obs)
Chri1
Postby Chri1 » Mon May 13, 2019 10:54 am
Thanks
A first attempt worked out:
I typed in Phyton-Console:
import DraftSnap
def cb(point):
    if point:
        print (point)
and with every
FreeCADGui.Snapper.getPoint(callback=cb)
I get the the snapped point of an existing object
(Depending on the current snap-settings)
There seem to be a lot more options to discover
Chri1
