Freecad 0.18 on OSX 10.14.4 and Spacemouse - not recognised
Brutha
Re: Freecad 0.18 on OSX 10.14.4 and Spacemouse - not recognised
Postby Brutha » Fri May 17, 2019 7:30 am
looo wrote:
Thu May 16, 2019 4:07 pm
Then I guess we should add libspnav to conda-forge. Shouldn't be too much trouble for linux/osx. Not sure about windows.
I'm not sure that libspnav is an option for OSX - at least, I think it never used to be, since the homepage says it supports only serial spacenavs on OSX - and I guess most people (like me!) use the USB ones now:
http://spacenav.sourceforge.net/index.html
But having said this, I found this post which suggest someone at least was looking at OSX usb compatibility, I have no idea if this patch was merged:
https://sourceforge.net/p/spacenav/patches/7/
There is some possibly out of date info on the FreeCAD side here:
https://www.freecadweb.org/wiki/3Dconne ... ut_devices
Really, until now I didn't know about it at all.
I find it's very nice: once you have trained your left hand to use it, it's like holding the object in your left hand. It takes a couple of hours to train your muscles, bit like riding a bicycle or something, but then it becomes quite instinctive.
Cheers
Brutha
Jee-Bee
Postby Jee-Bee » Fri May 17, 2019 8:09 am
USB is the abbreviation of "Universal Serial Bus". so it support it. see https://en.wikipedia.org/wiki/USB
Brutha
Postby Brutha » Fri May 17, 2019 8:15 am
Yes, I am sure you are correct there! But I suspect they intended to differentiate the two things on the Spacenav web page:
Spacenavd (as of version 0.6) supports all USB 3Dconnexion 6dof devices on GNU/Linux systems. Serial spaceball devices are also supported on GNU/Linux, FreeBSD, and MacOS X.
Jee-Bee
Postby Jee-Bee » Fri May 17, 2019 8:34 am
Do you have the normal drivers installed... I can't remember that i had to install spaccenav on OSX...
Brutha
Postby Brutha » Fri May 17, 2019 8:40 am
Hi, yes, I have the normal 3Dconnexxion drivers, I don't believe that FreeCAD ever used the Spacenav stuff (edit: on OSX I mean, I think it used it for Linux!).
wsy
Postby wsy » Fri May 17, 2019 5:42 pm
I can confirm the same problem on Linux - the current Linux release Spacenavd drivers work (*) on FreeCAD 0.17 (build 13541) AppImage, but do not work on 0.18 (release build 16110) or the 0.19 (prelim build 16718) AppImages.
Indeed, what I get on 0.18 and 0.19 in Customize > Spaceball Motion is "No Spaceball Present".
(*) by "work" I mean XYZABC motion. Buttons are acked but don't actually work even on 0.17.
- Bill (log attached for failing 0.19 AppImage)
FreeCAD.log
Log with failure to find spacemouse
(10.55 KiB) Downloaded 15 times
JohnForeman
Postby JohnForeman » Thu May 23, 2019 9:00 pm
an addon to this issue. My spaceball is working fine, but unlike the previous versions of FreeCad, once i mouse click outof the model window, the spaceball stops working until i click back on the model window. Is this a known issue or a new setting i need to adjust?
-John Foreman
Version: 0.18.16110 (Git)
Branch: (HEAD detached at upstream/releases/FreeCAD-0-18)
Python version: 3.6.6
Qt version: 5.6.2
hajduk
Postby hajduk » Mon Jun 03, 2019 11:02 am
Brutha wrote:
Thu May 16, 2019 10:12 am
Hi Hajduk,
I believe the reason is that the system they are compiling the Freecad binaries on now does not have the 3Dconnexion drivers installed.
Following Vectronic's instructions, I compiled a version myself with space mouse support, see link below. This seemed to work quite nicely, but may be a struggle if you are not familiar with the Terminal.
https://forum.freecadweb.org/viewtopic. ... 43#p307643
Cheers
Brutha
Dear Brutha,
hm, I am quite capable in terminal.app (old unix usage), but to be honest, currently I don't like setting up new package management etc.
So this would be for me quite a big step.
Currently I switched back to 0.17 and am happy with the little spare time I have.
If this problem continues, I will look into compilation..
And yes, the 3Dconnexion space mouse is definitely worth every penny!
It can be had 2nd hand for little money.
Best regards
Martin
vlish
Postby vlish » Sun Dec 01, 2019 8:02 am
+1, same problem here.
The latest version (0.18-16131) installed from homebrew does not recognize my Spacemouse Wireless.
FreeCAD_0.19-18811-OSX-x86_64-conda-Qt5-Py3.dmg (from GitHub releases) does not work either.
At the same time, FreeCAD_0.17-13541.9948ee4-OSX-x86_64-Qt5.dmg works fine out of the box.
steve123
Postby steve123 » Sat Feb 01, 2020 7:49 pm
Any further word on this? It appears the 3D mouse is still not working.
OS: macOS Mojave (10.14)
Version: 0.19.19323 (Git)
Hash: 1b198453b8eb6aa2eaca4e4be4b49fee74e9de6e
Python version: 3.8.1
Qt version: 5.12.5
OCC version: 7.4.0
Locale: C/Default (C)
