Compile Issues on Windows using latest Libpack
Zig_mint
Postby Zig_mint » Mon May 13, 2019 1:57 pm
hello,
I have been trying to compile freecad latest version from github on windows 10 and Microsoft VS 2019 and Libpack 12.1.2 x64
I happen to come across this error using Cmake 3.14. Any suggestions on what I should do
Found unsuitable Qt version "5.12.1" from C:/Users/RUPESH/Desktop/PROJECTS/SOP/FreeCAD/FreeCADLibs_12.1.2_x64_VC15/bin/qmake.exe
Qt QTOPENGL library not found.
Qt QTSVG library not found.
Qt QTUITOOLS library not found.
Qt QTWEBKIT library not found.
Qt QTGUI library not found.
Qt QTXML library not found.
Qt QTNETWORK library not found.
Qt QTCORE library not found.
CMake Error at CMakeLists.txt:851 (MESSAGE):
  Qt4 libraries not found.
Jee-Bee
Re: Compile Issues on Windows using latest Libpack
Postby Jee-Bee » Mon May 13, 2019 1:59 pm
it uses Qt5...
Zig_mint
Postby Zig_mint » Mon May 13, 2019 2:38 pm
If it uses Qt5.......how do I fix this error?
PS: I am new to cmake.
DeepSOIC
Postby DeepSOIC » Mon May 13, 2019 4:02 pm
Set BUILD_QT5 to ON in CMakeCache.txt (or wherever you tweak them, I do it in Qt Creator, but it is also doable with CMake-gui, and maybe with Visual Studio).
Zig_mint
Postby Zig_mint » Tue May 14, 2019 8:37 am
Thanks for the quick reply. I was able to correct the error and was even able to build the FreeCAD from visual studio 2019. Now when I run the Freecad.exe file from the build-directory/bin/freecad.exe I get the error saying
The code execution cannot proceed because Qt5Core.dll was not found. Reinstalling the program may fix this problem.
I have already tried reinstalling the application twice. i wonder why is the application is searching for Qt5 on my system when it has already been told to use it from LibPack.
Zig_mint
Postby Zig_mint » Tue May 14, 2019 9:38 pm
Thank you apeltauer, this post was very helpful and I am now able to compile and run FreeCAD. Following are the version details for those who wish to know
Windows SDK version 10.0.17763.0 to Windows 10.0.17134.
Compiler: MSVC, version: 19.20.27508.1
Cmake 3.14.3
FreeCAD Vulcan version 0.19.16100
sgrogan
Postby sgrogan » Tue May 14, 2019 9:44 pm
Glad it working.
We recently tagged an update to 0.18.2 https://github.com/FreeCAD/FreeCAD/tree ... eeCAD-0-18
"fight the good fight"
