Ticket #3978 - reference sketch dimensions lose their reference mode
uwestoehr
Postby uwestoehr » Thu May 16, 2019 10:35 pm
The sketcher has the nice feature to just measure dimensions by setting them in reference mode. But whenever I want to use the feature I loose the reference mode:
- take e.g. the attached simple sketch. There are several reference-mode dimensions in it
- double click on a reference-mode dimension and then do nothing, just press cancel
result: the dimension is no longer in reference mode but a normal mandatory dimension (turns from blue to red)
- now double click on a reference-mode dimension and then highlight in the appearing dialog the number and copy it to the clipboard
- finally press cancel (so that you did not actually change the dimension)
result: the dimension is also no longer in reference mode
The problem is that in real life documents the suddenly new real dimensions make sketches over-constrained. Moreover the change from reference-mode for the dimensions cannot simply be undone. Therefore it is really hard to work with the reference mode.
I am not sure it is a bug or I miss just a setting. Astonishingly I cannot find anything related to this issue in the forum so any hint is highly appreciated.
Mod edit: added ticket number to title + typo fix loose->lose
Sketcher-problem.FCStd
file to reproduce
(5.91 KiB) Downloaded 19 times
openBrain
Re: reference sketch dimensions loose their reference mode
Postby openBrain » Thu May 16, 2019 10:38 pm
I can confirm this was already discussed here some months ago. ;)
I probably can manage to find a link on tomorrow.
Postby chrisb » Thu May 16, 2019 11:11 pm
Abdullah has participated in the discussion mentioned by openBrain and favours the current behaviour. As there are use cases where the current behaviour is sensible, it probably will not be changed.
Both use cases are rare anyway.
bejant
Postby bejant » Fri May 17, 2019 2:01 am
This one?
https://forum.freecadweb.org/viewtopic. ... 14#p282314
And there's already a ticket mentioned in that thread...
kisolre
Postby kisolre » Fri May 17, 2019 5:59 am
I recently also stumbled upon this. In the past i used reference dimensions to check bounds of their values and lastni convert them to driving in that range. But "cancel" not canceling an action is not right.
uwestoehr
Postby uwestoehr » Fri May 17, 2019 9:43 am
This one?
Thanks bejant!
I think the issue here is different, the other topic and ticket is about naming.
You are right, it is a cancel action and thus must simply cancel, nothing more. I opened issue #3978 to address this.
abdullah wrote:
Fri Jan 25, 2019 3:09 pm
a blue Constraint should only become red if the Length / Angle field is edited.
Yes.
abdullah
Postby abdullah » Fri May 17, 2019 12:19 pm
Yes.
Sometimes you might (rightly) want to (mis)use this feature to make a constraint driving with the same value.
In my mind I was having something like:
Click "cancel" => remains blue.
Click "ok":
=> name was added?
+if yes,
remain blue;
else
change to red.
Because I do not like that clicking ok has differing behaviour (red/blue), I was thinking of disabling the value editor if the string of the reference is changed (or a new one is added). This way the user is pointed out that "ok" has nothing to do with the value when changing the string of the name.
Any issue with this implementation?
uwestoehr
Postby uwestoehr » Fri May 17, 2019 12:31 pm
But then you can select the dimension and use the corresponding toolbar button to turn it into driving.
Yes, but currently this is not the case. Even when cancelling it turns red.
Click "ok":
=> name was added?
+if yes,
remain blue;
else
change to red.
So you want this is or should this already be the case?
I am opposed to "magic". If I open a reference dimension and then press OK without changing it, I did not change it so why should it automatically be changed? A good UI should only do what the user tells it should do.
So if possible please only remove the reference mode if the user changes the value because then the dimension is no longer a reference but driving. In all other cases keep the mode. If a reference should become driving we have the toolbar button to do this. If you need a second dimension with the same value, you can just add such a second one.
(Personally I use reference dimensions for construction works and therefore I open reference dimensions to copy its value to the clipboard (in order to paste them to a math program etc.).)
openBrain
Postby openBrain » Fri May 17, 2019 12:38 pm
Correct. Magics of timezone. :) You find it during my sleep time. ;)
Click "ok":
=> name was added?
+if yes,
remain blue;
else
change to red.
Better if "=> (name was changed) and (value was unchanged)". ;)
But there is a corner case where the user manually enters the same exact value and expect the constraint to become driving.
IMHO, the best solution would be that there is a toggle button in the constraint editing box that both indicates current state (driven or driving) and allows the user to switch mode.
EDIT : another acceptable solution would be that a driven(reference) dimension always displays an editing value of something like "#ref". If the user change it for a number, then it become driving.
Postby chrisb » Fri May 17, 2019 8:30 pm
You should cross link these very similar issues. The source of the issues is exactly the same. In such cases it may even be better to add to a ticket than to create a new one.
