removeEventCallbackPivy from console
Chri1
Postby Chri1 » Mon May 20, 2019 11:57 am
Hi
I have an EventCallback which fixes an AnnotationLabel at the Cursor and is finished by mouse-left-click:
import FreeCADGui, Part
from pivy.coin import *
import FreeCAD
App = FreeCAD
import Draft
objectAnn = None
class cursorInf:
    global objectAnn
    global gp
    def __init__(self):
        print("anf")
        FreeCADGui.runCommand("Draft_Line")
        print("end")
        global objectAnn
        objectAnn = App.ActiveDocument.addObject("App::AnnotationLabel","FCInfoToMouse")
        self.view = FreeCADGui.ActiveDocument.ActiveView
        self.callback = self.view.addEventCallbackPivy(SoEvent.getClassTypeId(),self.getpoint)
        print(self.callback)
        gp = self.callback
        objectAnn.LabelText=["Hello"]
    def getpoint(self,event_cb):
        global objectAnn
        event = event_cb.getEvent()
        if type(event) == SoMouseButtonEvent:
             self.view.removeEventCallbackPivy(SoEvent.getClassTypeId(),self.callback)
             print("Ende")
        else:
             #print("Callback")
             pos = event.getPosition()
             point = self.view.getPoint(pos[0],pos[1])
             objectAnn.BasePosition = point
How can I finish the callback from outside - from python-console or another function?
I tried quite a bit like
Gui.ActiveDocument.ActiveView.removeEventCallbackPivy(SoEvent.getClassTypeId(), ??something with callback?? ) but I didn't succeed
Maybe this would help: How can I simulate a mouse-click by python code?
Thanks Chri1
Site Admin
Re: removeEventCallbackPivy from console
Postby wmayer » Mon May 20, 2019 3:32 pm
from pivy import coin
inst = cursorInf()
inst.view.removeEventCallbackPivy(coin.SoEvent.getClassTypeId(), inst.callback)
Chri1
Postby Chri1 » Tue Aug 13, 2019 3:07 pm
Another question:
The Information should be visible only until mouseclick.
But whole FreeCAD crashes with:
        global objectAnn
             print("Ende")
             objectAnn.Document.removeObject(objectAnn.Name)   # !!!!!!!!!!!!!!!!!          HERE IT CRASHES
Thanks
Chri1
Joel_graff
Postby Joel_graff » Tue Sep 24, 2019 2:14 pm
Is your object reference valid?
You might want to save a reference to the document separately, typically using App.ActiveDocument.
