Addon Manager improvements
Locked
yorik
Founder
Post by yorik »
Starting a topic to announce, well, Addon Manager improvements... :D
You can now restart FreeCAD directly from the addons manager, after installing a workbench/module.
microelly2
Re: Addon Manager improvements
Post by microelly2 »
This trick will speed up developement too. :mrgreen:
kisolre
Post by kisolre »
Edit: Shouldn't you include revision number where the feature was introduced to avoid confusion if it is available on existing builds?
I am not sure how those 16808 number are called but shouldn't you include that to avoid "It is not here yet" confusions? Just asking...
kisolre wrote: Tue May 21, 2019 7:29 pm I am not sure how those 16808 number are called but shouldn't you include that to avoid "It is not here yet" confusions? Just asking...
If it's the number as in 0.19.16808, then it's the revision number.
Post by Kunda1 »
yorik wrote: Tue May 21, 2019 7:21 pm You can now restart FreeCAD directly from the addons manager, after installing a workbench/module.
YES!
hammax
Post by hammax »
… I just have downloaded
FC 19.16817_x86 on Win10_32
and it doesn't work at all ?????
Running the Python command 'Std_AddonMgr' failed:
  File "C:\FC.19\FreeCAD_0.19.16817_x86_LP_11.11_PY2QT4-WinVS2013\Mod\AddonManager\AddonManagerGui.py", line 10, in Activated
    import AddonManager
('invalid syntax', ('C:\\FC.19\\FreeCAD_0.19.16817_x86_LP_11.11_PY2QT4-WinVS2013\\Mod\\AddonManager\\AddonManager.py', 306, 28, '                ret = m.exec()\n'))
Syres
Post by Syres »
hammax wrote: Wed May 22, 2019 6:03 am … I just have downloaded
    import AddonManager
Try changing line 306 in AddonManager.py from:
                ret = m.exec()
to:
                ret = m.exec_()
This appears to work on both Py2 and Py3.
easyw-fc
Post by easyw-fc »
yorik wrote: Tue May 21, 2019 7:21 pm Starting a topic to announce, well, Addon Manager improvements... :D
One risky issue:
If you have started a new design or you have modified one, and then you run the Addon Manager, clicking OK to restart FreeCAD will skip the check to Save your work, before restarting FreeCAD. Any changes will be lost without even a rescue option.
(tested with FreeCAD_0.19.16817_x64_LP_12.1.2_PY3QT5-WinVS2015)
Founder
Post by wmayer »
exec is a built-in function in Py3 but seems to be a keyword in Py2. So, using it to show a QDialog works with Py3 but raises a syntax error in Py2. Although Py3 is now the default Python version since v0.19 I think it would still be good to make it working with Py2.
One risky issue:
It's not only risky wrt data loss but it also makes the application crash. I created a document and added a body feature and after installing a plugin I confirmed to restart FreeCAD. The new instance started but the old instance caused a crash.
So, instead of forcing the event loop to stop (using QApplication.quit()) it's safer to use MainWindow.close().
if Gui.getMainWindow().close():
    QtCore.QProcess.startDetached(QtGui.QApplication.applicationFilePath(),args)
Internally this calls MainWindow::closeEvent that asks the user to save the document, discard it or just to cancel and if needed cleans-up everything so that FreeCAD can be safely closed. If the operation is cancelled close() returns False and True otherwise.
Another thing:
If you open the Addonmanager then it shows a green check mark for all installed plugins and in parentheses it shows "Installed". But when installing a new one then all check marks suddenly disappear. Furthermore it would be good to give a visual feedback after installing a new plugin, e.g. showing an orange check mark and in parentheses write "Restart" or "Require restart".
yorik
Founder
Post by yorik »
All suggested changes done in git commit 73c1a9c9a!
Thanks for the feedback guys!
Locked
