OpenCamLib is not working! Fixed for python 2.7
freman
Re: OpenCamLib is not working!
Postby freman » Thu May 30, 2019 10:45 am
Thanks, so what is the bottom line here?
Is there a fix or is FreeCAD broken until someone at OCL debugs the bindings mess?
What does this affect, can it just be ignored?
mlampert says:
you actually need to build the python 3 ocl bindings
How do you do that ?
herbk
Postby herbk » Thu May 30, 2019 11:18 am
OCL is only used for creating 3D milling path and it's the only thing what is not working for me.
Gruß Herbert
herbk
Postby herbk » Thu May 30, 2019 11:23 am
looo wrote:
Thu May 30, 2019 10:43 am
....Once done ocl can be installed via conda and we can include the results in the bundles (appimage/ dmg) if wanted.
Having OCL as part of FC would be great...
Gruß Herbert
sgrogan
Postby sgrogan » Thu May 30, 2019 12:52 pm
Guys, notice freman's OP, he's using Py2
sgrogan
Postby sgrogan » Fri May 31, 2019 9:22 pm
I little more research and I think libocl.so is the C++ library. The python binding should be ocl.so.
I don't have a working linux box at the moment, but who has cmake-gui and wants to be my eyes?
EDIT: Who has working an ocl and how? OS/Distro/PY2-3? Maybe also CMake version boost detection seems different on more recent cmakes.
freman
Postby freman » Fri May 31, 2019 10:07 pm
file /usr/local/lib/opencamlib/libocl.so.2018.08.122
/usr/local/lib/opencamlib/libocl.so.2018.08.122: ELF 64-bit LSB pie executable, x86-64, version 1 (GNU/Linux), dynamically linked, BuildID[sha1]=74a492995509aff8809bb1b55dd5e7a310c89e60, not stripped
I have just installed cmake-gui, never used it.
sgrogan
Postby sgrogan » Fri May 31, 2019 10:30 pm
If you run
cmake-gui .
from the ocl build directory, what does it look like? Mine is like this on Win (there are problems), notice I have Grouped and Adavanced checked.
freman
Postby freman » Fri May 31, 2019 11:25 pm
I ran configure and PY_BUILD_LIB and USE_PY_3 are not checked.
Nothing about python under boost.
the text window notably shows this:
Detecting CXX compile features - done
 Note: will NOT build python library
 Note: will NOT build emscripten library
C++ compiler version: 8.3.1 [/bin/c++]
I then checked the missing items and reran configure, the result is below.
I checked with my package manager:
Package boost-python3-devel-1.66.0-14.fc29.x86_64 is already installed.
Package boost-python2-devel-1.66.0-14.fc29.x86_64 is already installed.
Package python3-devel-3.7.3-3.fc29.x86_64 is already installed.
sgrogan
Postby sgrogan » Sat Jun 01, 2019 12:42 am
You should not check USE_PY_3.
Your OP shows that your FreeCAD uses 2.7.x, you want to match this version.
freman
Postby freman » Sat Jun 01, 2019 7:29 am
OK, I flipped that one off again. There seems to be some double use going on.
CMake Error at src/cxxlib/cxxlib.cmake:5 (add_subdirectory):
  The binary directory
    ~/opencamlib/src/cutters
  is already used to build a source directory.  It cannot be used to build
  source directory
  Specify a unique binary directory name.
  src/CMakeLists.txt:254 (include)
I get this for all the subdirectories at that level. I manually removed them and re-ran, it produced the same errors. No idea whether that is a real problem.
During building FreeCAD there was similar messages about not finding Boostdir but later output clearly showed it had detect boost 1.6.6 . As noted above, both boost-python devel packages are installed as are the two versions of python headers.
Package python2-devel-2.7.15-11.fc29.x86_64 is already installed.
