Function when a workbench opens a new file.
keithsloan52
Re: Function when a workbench opens a new file.
Postby keithsloan52 » Sun Jun 02, 2019 6:34 pm
I believe @ickby is the developer for the DocObserver perhaps he/she could comment.
ickby
Postby ickby » Mon Jun 03, 2019 11:27 am
I only extended the system sligthly. Have a look at the test cases, there you get a good impression how to use the observers. They are registered in the tests setup method and unregistered in the tests teardown method
With your code I don't get the same error, and the objects are created after opening the file. The only thing I spot is that you define "doc" as a local variable to the function, hence you can't use it in deactivate. You should store the document observer and use the stored object for removing it again.
keithsloan52
Postby keithsloan52 » Tue Jun 04, 2019 5:29 pm
Still cannot spot where the problems is here are my version details
OS: Ubuntu 18.04.2 LTS
Version: 0.18.1.
Python version: 3.6.7
Qt version: 5.9.5
keithsloan52
Postby keithsloan52 » Tue Jul 16, 2019 2:42 pm
Need now to sort this but still no joy, When you tried my code did you put it in InitGui.py? @ickby
keithsloan52
Postby keithsloan52 » Tue Jul 16, 2019 3:59 pm
Getting more convinced this is a problem because I am trying to define the workbench in InitGui.py and also the Observer class.
So where else do people put them?
keithsloan52
Postby keithsloan52 » Tue Jul 16, 2019 7:08 pm
keithsloan52 wrote:
Fri May 31, 2019 9:47 am
Okay I am missing something as I get the follow error message
name 'DocObserver' is not defined
  File "<string>", line 65, in Activated
My code in InitGUI.py looks like
import FreeCAD
class DocObserver(object):
    def slotCreatedDocument(self, doc):
        mySphere = doc.addObject("Part::Sphere", "Globe")
        mySphere.Radius = 100
class Astro_Workbench ( Workbench ):
    "Astro workbench object"
    def __init__(self):
        self.__class__.Icon = FreeCAD.getResourceDir() + "Mod/Astro/Resources/icons/AstroWorkbench.svg"
        self.__class__.MenuText = "Astro"
        self.__class__.ToolTip = "Astro workbench"
    def Initialize(self):
        def QT_TRANSLATE_NOOP(scope, text):
            return text
        import AstroCommands
        commands=['AddRegionCommand' ]
        toolbarcommands=['AddRegionCommand']
        self.appendToolbar(QT_TRANSLATE_NOOP('Workbench','AstroTools'),toolbarcommands)
        self.appendMenu('Astro',commands)
        #FreeCADGui.addIconPath(":/icons")
        FreeCADGui.addIconPath(FreeCAD.getResourceDir() + \
                              "Mod/Astro/Resources/icons")
        FreeCADGui.addLanguagePath(":/translations")
        #FreeCADGui.addPreferencePage(":/ui/openscadprefs-base.ui","OpenSCAD")
    def Activated(self):
        "This function is executed when the workbench is activated"
        doc=DocObserver()
        App.addDocumentObserver(doc)
        return
    def Deactivated(self):
        "This function is executed when the workbench is deactivated"
        App.removeDocumentObserver(doc)
        return
           def GetClassName(self):
        "This is executed whenever the user right-clicks on screen"
        return "Gui::PythonWorkbench"
        return
    def ContextMenu(self, recipient):
        # "recipient" will be either "view" or "tree"
        #self.appendContextMenu("My commands",self.list) # add commands to the context menu
Gui.addWorkbench(Astro_Workbench())
Will have to give the FreeCAD python console a try I am still on the old fashioned way of doing things
Should the class definitions be nested somehow?
keithsloan52
Postby keithsloan52 » Wed Jul 17, 2019 5:09 am
Don't suppose I could get somebody for example @ickby or @wmayer to check my code as I am at a total loss of what the problem is
github respository https://github.com/KeithSloan/FreeCAD_Python_GDML
branch with problem default.
With GDML workbench installed if I switch the the GDML workbench I get the error
Activated
name 'MyObserver' is not defined
  File "<string>", line 84, in Activated
ickby
Postby ickby » Thu Jul 18, 2019 5:52 am
the problem seems to be that the classes created in the InitGui.py are not usable... I really don't know why, I have no clue where their definition goes too and how theys are accessbile... maybe werner knows more? But as a workaround you could make the observer a inner class of the workbench, this works:
# GDML wrkbench gui init module
# Gathering all the information to start FreeCAD
# This is the second one of three init scripts, the third one
# runs when the gui is up
#*   (c) Juergen Riegel (juergen.riegel@web.de) 2002                       *
#*   This file is part of the FreeCAD CAx development system.              *
#*   This program is free software; you can redistribute it and/or modify  *
#*   it under the terms of the GNU Lesser General Public License (LGPL)    *
#*   as published by the Free Software Foundation; either version 2 of     *
#*   the License, or (at your option) any later version.                   *
#*   for detail see the LICENCE text file.                                 *
#*   FreeCAD is distributed in the hope that it will be useful,            *
#*   but WITHOUT ANY WARRANTY; without even the implied warranty of        *
#*   MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the         *
#*   GNU Lesser General Public License for more details.                   *
#*   You should have received a copy of the GNU Library General Public     *
#*   License along with FreeCAD; if not, write to the Free Software        *
#*   Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307  *
#*   USA        *
#*   Juergen Riegel 2002                                                   *
#* Also copyright Keith Sloan                                              *
#import FreeCAD
from FreeCAD import *
from importGDML import processGDML
import PartGui
import GDMLCommands, GDMLResources
class GDML_Workbench ( Workbench ):
    class MyObserver():
        def __init__(self):
            self.signal = []
            processGDML(FreeCAD.getResourceDir() + "Mod/Resources/Default.GDML")
    "GDML workbench object"
    def __init__(self):
        self.__class__.Icon = FreeCAD.getResourceDir() + "Mod/GDML/Resources/icons/GDMLWorkbench.svg"
        self.__class__.MenuText = "GDML"
        self.__class__.ToolTip = "GDML workbench"
        #self.obs = MyObserver()
            return text
        #import GDMLCommands, GDMLResources
        commands=['CycleCommand','BoxCommand','ConeCommand','ElTubeCommand', \
                  'EllipsoidCommand','SphereCommand', \
                  'TrapCommand','TubeCommand']
        toolbarcommands=['CycleCommand','BoxCommand','ConeCommand', \
                         'ElTubeCommand', 'EllipsoidCommand','SphereCommand', \
        parttoolbarcommands = ['Part_Cut','Part_Fuse','Part_Common']
        self.appendToolbar(QT_TRANSLATE_NOOP('Workbench','GDMLTools'),toolbarcommands)
        self.appendMenu('GDML',commands)
        self.appendToolbar(QT_TRANSLATE_NOOP('Workbech','GDML Part tools'),parttoolbarcommands)
                              "Mod/GDML/Resources/icons")
        FreeCADGui.addPreferencePage(":/ui/GDML-base.ui","GDML")
        #print(FreeCAD.getResourceDir() + "Mod/Resources/ui/GDML-base.ui")
        print ("Activated")
        print(self.GetClassName())
        #MyObserver()
        #App.addDocumentObserver(self.doc)
        self.obs = self.MyObserver()
        App.addDocumentObserver(self.obs)
        return
        App.removeDocumentObserver(self.obs)
        return
class testClass():
    def __init__(self):
        self.signal = []
Gui.addWorkbench(GDML_Workbench())
ickby
Postby ickby » Thu Jul 18, 2019 5:55 am
I also found that it is not enough to import things in the init file for the observer, e.g. the processGDML must be imported in the function itself to be accessible:
    class MyObserver():
        def __init__(self):
            self.signal = []
From there on I cannot test anymore as I do not have lxml available.
keithsloan52
Postby keithsloan52 » Thu Jul 18, 2019 3:40 pm
Many thanks - now works a treat.
