Draft 2D plan to drawing
HDM
Postby HDM » Thu May 30, 2019 3:18 pm
Ok, so im completely new to this and probably out of my depth a little so any help is appreciated!
Stumbled upon freeCAD looking to do a simple plan view of garden area that i want converting. I've managed to draw a 2D plan out as per measurements of garden and added dimensions to various sections.
How do i now add this to a drawing sheet for saving/printing. Only work around I've got currently is to export to pdf but it lowers the quality so much some of the text is hard to read
My plan view is as basic as they come, mostly made up of rectangles and lines with the dimension tool showing various lengths
Thanks in advance for any assistance
quick61
Re: Draft 2D plan to drawing
Postby quick61 » Thu May 30, 2019 3:45 pm
TechDraw Module, that is if you managed to follow at least #2 in the instructions that are linked at the top of the page. ;)
Basic TechDraw Tutorial
Mark
HDM
Postby HDM » Thu May 30, 2019 3:56 pm
Mark
I'll take a look :shock:
meme2704
Postby meme2704 » Fri May 31, 2019 10:06 am
Hi
You do not tell us which workshop you use
If you want to make an unpretentious design, you can use the Sketcher workshop and its tools of dimensional constraint, then use the Windows capture tool (if you are under windows) and an impression, you will have a very clear drawing but without scale, and if you use Paint (for example) you can add anotations
