[Solved] [Bug] Fullscreen issue with 'Part' containers
easyw-fc
Postby easyw-fc » Fri May 31, 2019 10:28 am
I have noticed the following issue when displaying a document with a 'Part' container in fullscreen:
All 'Part' container Axis get displayed and closing fullscreen, will force the Axis containers to be always displayed until the doc get closed and re-opened.
phpBB [video]
Here my FC details, but it has the same issue on Win
OS: Linux Mint 19.1
Version: 0.18.1.
Python version: 3.6.7
Qt version: 5.9.5
Version: 0.18.16117 (Git)
Branch: releases/FreeCAD-0-18
Hash: dbb4cc6415bac848a294f03b80f65e888d531742
Python version: 3.6.6
Qt version: 5.6.2
It is present also on FC019 daily
Reason: Added [Solved] to thread title
kisolre
Re: Fullscreen issue with 'Part' containers
Postby kisolre » Fri May 31, 2019 10:45 am
Here it happens with everything in the body - after exiting "document window fullscreen mode" (or at enteringr it?) it stops respecting its parrent visibility state.
OS: Windows 8.1
Version: 0.19.16687 (Git)
Hash: ff1fb11af15a7c5f7f0ba3ef79588e128f397c2c
Qt version: 5.6.2
edit: after trying with more complex file and two files open this giberish happened:
Two copies of the ring from one file, random parts appear while moving the mouse from the hole punch.
kisolre
Postby kisolre » Fri May 31, 2019 12:20 pm
After some more play I got this: :D :D :D :D
freecad futuristic.JPG (94.67 KiB) Viewed 827 times
easyw-fc
Re: [Bug] Fullscreen issue with 'Part' containers
Postby easyw-fc » Sat Jun 01, 2019 10:51 am
Does it create also a memory leak?
FreeCAD goes completely mad with Part Design objects if used on fullscreen...
kisolre
Postby kisolre » Sat Jun 01, 2019 10:54 am
Did not check then. I will do some experiments when i get home.
easyw-fc
Postby easyw-fc » Tue Jun 04, 2019 8:31 pm
Should I report it to Mantis?
kisolre
Postby kisolre » Wed Jun 05, 2019 6:44 am
Definitely.
Today after exiting fullscreen the whole view got black. Other document opened in the same time looks Ok. But creating new view with that black view open made the whole FreCAD window to black/white giberish. Did not see a memory leak (huge memory usage).
OS: Windows 8.1 (6.3)
Version: 0.19.16886 (Git)
Hash: ed47e962d2c821bf1792889f6d7bdf457dcf6c9e
Python version: 3.6.8
Qt version: 5.12.1
NVidia graphics if it relevant. But similar happens with integrated Intel.
Site Admin
Postby wmayer » Wed Jun 05, 2019 10:16 am
This issue is Qt5-related.
With our old Qt4 builds all this worked without any problems and with Qt5 the OpenGL support has been reworked causing many, many problems.
For me switching to fullscreen seems to work fine with Qt5.6 but switching back to normal mode causes some rendering artefacts. With Qt5.12 things are much worse: when in normal mode anti-aliasing is enabled then this will be lost when switching to fullscreen mode and when switching back the rendering looks worse and the 3d window has a huge offset, too.
From the beginning on the QOpenGLWidget class has some bad behaviour because it destroys the OpenGL context and an internal FBO when switching to fullscreen mode or back and thus loses all its settings. The workaround I once found was to simply create a new QOpenGLWidget and delete the old one when changing the mode which was working more or less fine. But with Qt5.12 this doesn't seem to work at all any more.
Postby Kunda1 » Wed Jun 05, 2019 11:39 am
@wmayer are these opengl issues documented so we can inform folks of this limitation(s) due to Qt?
Site Admin
Postby wmayer » Wed Jun 05, 2019 12:20 pm
The other issues I was talking about affects the off-screen rendering where for many people no image or an empty image is created. I have never seen this problem on any of my systems and I assume that's driver related.
Today I checked-in the commits git commit 2a1dd8415 and git commit 57b3ca6f and these fix the rendering problems I have with Qt5.12 on Windows and a crash on my (virtual) Ubuntu 18.04 with Qt5.9.5.
Now the remaining problem is when switching back from fullscreen to normal mode by pressing ESC. The Qt5.6 version loses the anti-aliasing settings and the 5.12 version additionally has an offset.
This however is not a Qt issue but a FreeCAD issue because pressing ESC directly changes the MDI view instead of cloning and deleting it. When pressing the shortcuts v,d or v,u instead then all works correctly for me.
So, the only change for now is to disable the ESC button inside View3DInventor::keyPressEvent when using Qt5.x
