If you select a dimension, then select an object, dimension label is moved:
Bug on dimension lines
- wandererfan
Re: Bug on dimension lines
Yes, I've seen this one. It comes from git commit 5cea2f83bc "Fix "trails" on dim lines when zoomed in".
The dimension and main view selection areas are overlapping. An ugly work around is to hide the dimension, then pick the view.
Still trying to figure out a fix.
OP, please always post your Help About FreeCAD 'Copy to clipboard to verify the version/revision of FC that you are using. Also for posterity. Thx
- wandererfan
Should be fixed by git commit 4494d384a6
