Ticket #4018 - Projecting an ellipse on an inclined plane
berka
Postby berka » Sat Jun 08, 2019 11:10 am
I'm working with a model that requires me to constrain to projections of an ellipse to faces in different planes.
I've confirmed with some Googling that the projections are ellipses as well. However, FreeCAD projects these as B-Splines. This is in Sketcher, as external geometry. That's not all that helpful.
I can easily make an ellipse as construction geometry on the Sketcher plane. I have the end points; I just need third point on the original geometry: e.g. the end point of the minor axis would be a good addition. (I may need the center as well, but that problem hasn't come up in my cases yet.)
Question: What is a good way to allow me to get the minor axis end point on my Sketcher plane as external geometry?
The best I can come up with is: break up the original ellipse segments into two segments each. It's just going to be unnecessarily cumbersome all over my parts.
An example demonstrating the issue is attached.
Overall Part:
Screen Shot 2019-06-08 at 06.43.55.png (32.37 KiB) Viewed 618 times
External Geometry as spline:
Screen Shot 2019-06-08 at 06.44.58.png (13.82 KiB) Viewed 618 times
My ellipse construction geometry to work around: I need that third point:
Screen Shot 2019-06-08 at 06.47.51.png (28.74 KiB) Viewed 618 times
OS: macOS 10.14
Version: 0.18.16117 (Git)
Branch: (HEAD detached at 0.18.2)
Hash: dbb4cc6415bac848a294f03b80f65e888d531742
Python version: 3.6.7
Qt version: 5.6.2
ellipseprojection.FCStd
(52.56 KiB) Downloaded 10 times
Reason: Updated thread title with bug tracker ticket number
meme2704
Re: Projecting an ellipse on an inclined plane
Postby meme2704 » Sat Jun 08, 2019 11:40 am
Hi
You have to try to find a straight segment to avoid a projection in B-spline
In this case make a cross section "provisional"
elipse.FCStd
(48.8 KiB) Downloaded 8 times
berka
Postby berka » Sat Jun 08, 2019 12:14 pm
Thank you. This sounds promising. Can you elaborate on how?
The "clipping plane" view option is greyed out in Sketcher. The only other related thing I found was "Sketcher->View Section" which is the wrong plane.
GlouGlou
Postby GlouGlou » Sat Jun 08, 2019 5:34 pm
Use a datumplane and datumpoint with proximity attachment mode between the sketch and edge. Then use the point for external geometry and hook the ellipse on it. ;)
aa.FCStd
(46.38 KiB) Downloaded 11 times
berka
Postby berka » Mon Jun 10, 2019 10:29 am
Thanks. That works beautifully since I know and can define the line along the top of my part.
Of course, I took two steps forward and hit another snag. I wanted to use the same idea for line/plane intersection. The plane is offset from the face a few mm.
Screen Shot 2019-06-10 at 06.18.45.png (47.2 KiB) Viewed 519 times
The Line/Plane proximity point fails with:
PositionBySupport: AttachEnginePoint::calculateAttachedPlacement: proximity calculation failed.
I've seen this before, and It's changed the way I model. Finding intersections of two planes or line to plane seem like pretty simple operations I should be able to do. Does anyone know how to achieve that?
GlouGlou
Postby GlouGlou » Mon Jun 10, 2019 12:41 pm
the proximity between datumline and datumplane works.
berka
Postby berka » Mon Jun 10, 2019 12:53 pm
Odd. It's never worked for me.
Screen Shot 2019-06-10 at 09.00.36.png (111.11 KiB) Viewed 497 times
berka
Postby berka » Tue Jun 11, 2019 1:35 am
If there are no objections, I'll start a bug report on this. It's possible it's a platform-dependent issue (MacOS).
Postby chrisb » Tue Jun 11, 2019 8:30 am
I will try to reproduce on the Mac. What are the exact steps?
berka
Postby berka » Tue Jun 11, 2019 11:41 am
You can try this file:
FCStd file from earlier in conversation, extended to show the plane/line intersection issue.
(52.91 KiB) Downloaded 13 times
1) Create a datum point
2) Select "DatumPlane Offset Incline" as a reference
3) Select "DatumLine Ridge" as a second reference
4) Try "Proximity Point 1" as Attachment mode.
The order of references doesn't matter. Proximity point 2 also does the same.
Alternately, you can start from a new file:
1) Create body
2) Create a Datum Plane (I used detached)
3) Create a Datum Line
4) Create a Datum point and try proximity point as above.
