install multiple version of a workbench
Postby bernd » Fri Jun 14, 2019 1:11 pm
What is the best way to install multiple versions of a workbench? The problem is all directories are added to Path. Thus there are all modules twice. Something is needed to say from which directory to import.
Re: install multiple version of a workbench
Postby chrisb » Fri Jun 14, 2019 8:15 pm
I think used to have in the pre-0.17 era the manually installed workbenches in the macro directory. You can use different config files and configure different macro directories.
Postby chrisb » Fri Jun 14, 2019 8:59 pm
I just tested it and it works. You need a Mod directory in the Macro directory, below that you place your workbenches.
triplus
Postby triplus » Sat Jun 15, 2019 9:00 am
I don't know which import style you use and there are some differences regarding Py2/Py3. But regardless of all that in the end you likely won't be able to use the same import statement for both modules. One will for example need to have an additional suffix, such as NameDev.py or name_dev.py. This therefore isn't all that much FreeCAD related, this is Python related.
looo
Postby looo » Sat Jun 15, 2019 6:06 pm
In python virtual envs are the way to test different versions of the same packages.
Postby bernd » Sat Jun 15, 2019 11:39 pm
thanks for all the answers
cron
