Mixing chamber - 2 inlets same medium , 1 outlet
Moderator: oliveroxtoby
Sidemountyucatan
Postby Sidemountyucatan » Mon Jun 24, 2019 10:32 am
Dear all,
I tried to solve another example for get myself more familiar with the CFD topic. It is a quite simple structure of
a pipe with 2 inlets (round shaped) and 1 outlet. The medium is the same for both inlets. I did meshing with cfmesh
and surface refinement at the inlets and outlet.
I tried a steady and a transient run.
Both did not work with certain boundary condition at the outlet.
Error message was:
21.1: OpenFOAM fatal error: Continuity error cannot be removed by adjusting the outflow.
21.2: Simulation exited with error
It has something to do with the boundary condition "outflow" because with "pressure" as boundary condition at the outlet it did
at least start to run eventhough residuals are somewhere in the dimension of 10^-1 to 10^-2 which is quite too high I guess.
I have the following questions:
(1) What is the issue with the "outflow" boundary ?
(2) How can I bring down the residuals ? Finer mesh in whole 3D model ? Mesh refinement )? Other values for k and w ?
Thx a lot !
Mixing chamber_dont work.FCStd
(90.8 KiB) Downloaded 6 times
Freecad version.jpg (245.74 KiB) Viewed 158 times
oliveroxtoby
Re: Mixing chamber - 2 inlets same medium , 1 outlet
Postby oliveroxtoby » Thu Jun 27, 2019 7:52 pm
Dear all,
Error message was:
Thx a lot !
The outflow boundary extrapolates all quantities and is only useful in rare conditions (this is why there is a warning to use with care). In most cases you need to specify some quantity at an outlet for it to be well posed.
Please provide all the information requested in this post before reporting problems with CfdOF.
