extraction of negative eigenvalues
HarryvL
Re: extraction of negative eigenvalues
Postby HarryvL » Sat Jul 06, 2019 12:19 pm
bernd wrote:
Sat Jul 06, 2019 10:50 am
- start FreeCAD
- load FEM 3D example
- change to analysis type frequency
- change from first 15 to first 8 frequencies
- delete constraint fixed and constraint force
- run analyisis
- the imaginary part in Hz is missing
- screen and file attached
test.FCStd
Box_Mesh.dat.txt
EDIT: see https://forum.freecadweb.org/viewtopic. ... 30#p319635
bernd
Postby bernd » Sat Jul 06, 2019 12:31 pm
I don’t understand. You have 5 values per line so the last one should be imaginary part in Hz as per my post.
no the number and four values ... see my screen from dat file !
bernd
Postby bernd » Sat Jul 06, 2019 2:01 pm
HarryvL
Postby HarryvL » Sat Jul 06, 2019 2:04 pm
HarryvL
Postby HarryvL » Sat Jul 06, 2019 2:06 pm
HarryvL
Postby HarryvL » Sat Jul 06, 2019 2:18 pm
Jee-Bee
Postby Jee-Bee » Sat Jul 06, 2019 3:27 pm
Why not using numpy arrays against math with a loop as you use now?
bernd
Postby bernd » Mon Jul 08, 2019 7:44 am
I am unsure, but we may do something totally wrong or missunderstand ...
Attached a screen. The green value is presentet to the user as Eigenmode Frequency for mode no 8. This is what FreeCAD does ATM. As far as I read the table ther is no imaginary part in cycles / time. Attached the screen again.
What makes me unsure is the Eigenvalue. AFAIK the eigenvalue is the natural frequency, but we have two columns one for Eigenvalue and one for the frequency ...
Mhh, I should do more earthqake analyses ... I would better know than ...
HarryvL
Postby HarryvL » Mon Jul 08, 2019 9:50 am
This is surprising and different from what I remember. I will look into it and compare to what I did for the bridge.
EDIT: the natural frequency in rad/s is the square root of the eigenvalue of the free vibration problem.
bernd
Postby bernd » Mon Jul 08, 2019 10:03 am
great
PS: yes the natural frequency in rad/s is the eigenvalue of the free vibration problem.
than what is the column eigenvalue for? Do you know some paper which explains all this without tons of integrals and matrix operations ... :oops: wikipedia does not a good job here IMHO.
