FreeCAD and Raspberry Pi 4
josegegas
Re: FreeCAD and Raspberry Pi 4
Postby josegegas » Thu Feb 13, 2020 7:16 pm
I compiled FreeCAD 0.18 on a Rpi 4 following this:
https://www.framboise314.fr/utiliser-fr ... GTSD63Ac1s
Took like 2 hours, but now it runs well.
Still have to test it properly though, but it seems that it works fine :D
Postby Kunda1 » Tue Feb 18, 2020 6:33 pm
This thread was featured on a blog that was featured on Hacker news
https://news.ycombinator.com/item?id=22347385
Janzsmboni
Postby Janzsmboni » Sun Feb 23, 2020 7:51 am
Hello everyone just landed on the blog and trying to figure out how to overcome this coin 3d issue and successfully install freeCad on the raspberry pi4, did anyone wrote up a straight forward guideline how to make it possible? Thank you for any feedback
tiedemate
Postby tiedemate » Sat Mar 14, 2020 12:13 am
Sorry, I totally missed this reply...
Ok, there is a conflicting type definition in the source code? But that can't be specific to my Pinebook Pro, or can it?
wmayer wrote:
Wed Dec 11, 2019 12:26 pm
tiedemate wrote:
Fri Nov 22, 2019 12:46 pm
I can't insert the output of the subsequent
make -j4
because it exceeds the character limit, so I attached it as a textfile.
The build fails because of this error:
In file included from /usr/include/qt4/QtOpenGL/QGLContext:1,
from /home/tiedemate/freecad-build/src/QtOpenGL.h:48,
from /home/tiedemate/freecad-source/src/Gui/Application.cpp:49:
/usr/include/qt4/QtOpenGL/qgl.h:85:17: error: conflicting declaration 'typedef GLfloat GLdouble'
85 | typedef GLfloat GLdouble;
In file included from /home/tiedemate/freecad-source/src/Gui/InventorAll.h:31,
from /home/tiedemate/freecad-source/src/Gui/Application.cpp:27:
/usr/include/GL/gl.h:134:17: note: previous declaration as 'typedef double GLdouble'
134 | typedef double GLdouble; /* double precision float */
There is a conflicting type definition of GLdouble. The OpenGL lib defines it as double but Qt re-defines it as GLfloat.
josegegas
Postby josegegas » Sat Mar 28, 2020 1:56 am
Hi all.
I have installed FreeCAD on my Raspberry pi 4 following these instructions:
FreeCAD works great on my Rpi, however, I cannot add any new workbench. The addon manager works and it says the workbench has been added, but when I re-starts FreeCAD the new workbench is not there. I have also tried by downloading and copping the workbench into my Mod folder, but did not work either. Actually, I realized I have two Mod folders, one in /home/pi/.FreeCAD/Mod, and one in the folder where I complied FreeCAD using the instructions in the link above. which is /home/pi/FreeCAD/freecad-build/Mod. I have copied the FCGear workbench to both Mod folder, but it does not work.
Any idea will be very appreciated!
Cheers.
-alex-
Postby -alex- » Mon Apr 13, 2020 5:59 pm
AFAIK /home/pi/FreeCAD/freecad-build/Mod is the folder which contains all standard WB, I mean built-in workbenches.
/home/pi/.FreeCAD/Mod is the folder which manages user settings and workbenches from addon manager, that's the right place concerning additional workbenches.
I installed sheetmetal WB or Fasteners WB with no trouble. Please try that and tell me.
Concerning FCGears, I have the same issue as you, FCGears WB marked as "installed" in addon manger but not available in scroll-list. I assume this trouble is due to PY2 compilation because FCGears is now PY3 suitable.
So, if I'm right, you could try to compile FreeCAD 18.4 with PY3/Qt4 then check if it works better.
Otherwise you could try to use PY2 branch of https://github.com/looooo/freecad.gears of FCGears:
looo wrote: ping
Looo, am I right? Sorry, I've got the answer, it works: thanks Looo for your PY3 and PY2 branches ;)
@josegegas:
clone or download https://github.com/looooo/freecad.gears/tree/py2 then unzip it by replacing /home/pi/.FreeCAD/Mod/FCGear containt. That works ;)
-alex-
Postby -alex- » Tue May 05, 2020 8:19 pm
Hi folks,
I have good news: FreeCAD 18.4 (PY3/Qt5) works like a charme on RPI4 with Ubuntu 20.04LTS :D
Installed from repository.
OS: Ubuntu 20.04 LTS
Version: 0.18.4.
Python version: 3.8.2
Qt version: 5.12.5
Locale: French/France (fr_FR)
I get some troubles with Xfce desktop (freezing sometimes...) but this is another story, not relevant with FreeCAD.
Enjoy FreeCAD on RPI4 with Ubuntu, I hope someday FreeCAD (PY3/Qt5) will work on Raspbian too :)
vocx
Postby vocx » Tue May 05, 2020 8:30 pm
I was just reading about Ubuntu's support of the Raspberry Pi. If FreeCAD works here, it's a win for Ubuntu.
Also please try 0.19, as it's obviously much more improved.
Also, you didn't mention whether you compiled it yourself, following, say, Compile on Linux, or if you installed it from the repository.
-alex-
Postby -alex- » Tue May 05, 2020 8:42 pm
yeap, that's my next step :D
but I have to fix first the freezing of desktop issue, otherwise I will turn crazy :evil:
Installed from repository, Edit:
sudo apt-get install freecad
vocx
Postby vocx » Tue May 05, 2020 8:49 pm
Installed from repository, thanks to Vejmarie I guess ;)
So, it's the snap version? Not the deb version? These details are important.
