FreeCAD-AppImages do not run under opensuse Tumbleweed (invalid magic cookies on tumbleweed)
adler53
Postby adler53 » Fri Jul 05, 2019 12:25 pm
If you run FreeCAD-Images from Version 0.18 up, you get this error:
adler@ad-oss:/opt/appimage> ./FreeCAD_0.18-16117-Linux-Conda_Py3Qt5_glibc2.12-x86_64.AppImage
/tmp/.mount_FreeCAiRZqo7
FreeCAD 0.18, Libs: 0.18R16117 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2019
Invalid MIT-MAGIC-COOKIE-1 key/tmp/.mount_FreeCAiRZqo7/AppRun: Zeile 12:  8540 Abgebrochen             (Speicherabzug geschrieben) ${HERE}/usr/bin/FreeCAD "$@"
This means, that FreeCAD is completely not compatible with Opensuse Tumbleweed, neither by zypper in FreeCAD, neither as AppImage.
The Installation with zypper in FreeCAD fails with
Problem: libpyside2.cpython-37m-x86_64-linux-gnu.so.5.12()(64bit) needed by FreeCAD-0.18.1-1.1.x86_64 cannot be provided
 Solution 1: do not install FreeCAD-0.18.1-1.1.x86_64
 Solution 2: FreeCAD-0.18.1-1.1.x86_64: ignore Depencies and risk an instable system
This means, that FreeCAD would -under opensuse Tumbleweed - be only available as WINDOWS-Version, working under WINE.
Reason: Updated title
Re: FreeCAD-Images do not run under opensuse Tumbleweed
Postby Kunda1 » Fri Jul 05, 2019 5:27 pm
Moved to install/compile subforum
Is this anissueyou can reproduce with any other appimages or just FreeCAD?
adler53
Postby adler53 » Fri Jul 05, 2019 6:03 pm
The error comes only up by the Appimages of Version 0.18 and 0.19.
FreeCAD 0.17 works fine and twoo other Appimages (Libreoffice and Blender) either do.....
DeronF
Re: FreeCAD-AppImages do not run under opensuse Tumbleweed
Postby DeronF » Wed Jul 17, 2019 9:12 pm
Hi..
FreeCAD 18.1 was working fine on my OpenSUSE tumbleweed machine until a system update few months ago .. when Python 3 updated the FreeCAD broke ..
Any attempt to reinstall it gives this:
x@x-pc:/> sudo zypper install FreeCAD
Retrieving repository 'openSUSE-Tumbleweed-Source-Non-Oss' metadata ..........................................................................[done]
Building repository 'openSUSE-Tumbleweed-Source-Non-Oss' cache ...............................................................................[done]
Loading repository data...
Reading installed packages...
Resolving package dependencies...
Problem: nothing provides libpyside2.cpython-37m-x86_64-linux-gnu.so.5.12()(64bit) needed by FreeCAD-0.18.1-1.1.x86_64
Solution 2: break FreeCAD-0.18.1-1.1.x86_64 by ignoring some of its dependencies
Choose from above solutions by number or cancel [1/2/c/d/?] (c):
schuderbalg
Postby schuderbalg » Wed Jul 24, 2019 7:13 pm
Create symlinks to version 5.13 of missing libraries, at least FreeCAD starts up:
schuderbalg@linux:/usr/lib64> sudo ln -s libshiboken2.cpython-37m-x86_64-linux-gnu.so.5.13 libshiboken2.cpython-37m-x86_64-linux-gnu.so.5.12
schuderbalg@linux:/usr/lib64> sudo ln -s libshiboken2.cpython-37m-x86_64-linux-gnu.so.5.13.0 libshiboken2.cpython-37m-x86_64-linux-gnu.so.5.12.0
schuderbalg@linux:/usr/lib64> sudo ln -s libpyside2.cpython-37m-x86_64-linux-gnu.so.5.13 libpyside2.cpython-37m-x86_64-linux-gnu.so.5.12
schuderbalg@linux:/usr/lib64> sudo ln -s libpyside2.cpython-37m-x86_64-linux-gnu.so.5.13.0 libpyside2.cpython-37m-x86_64-linux-gnu.so.5.12.0
looo
Postby looo » Wed Jul 24, 2019 7:31 pm
Can you change the topic title to:
"invalid magic cookies on tumble weed" ;)
I guess it's a hidden message from open suse devs.
please help with my conda-packaging efforts: https://liberapay.com/looooo/
minimalistic blog: https://looooo.github.io/mini-blog/
triplus
Postby triplus » Sun Aug 25, 2019 10:42 pm
Any openSUSE people around? Just wondering what is the current situation regarding FreeCAD 0.18/0.19 AppImages:
https://github.com/FreeCAD/FreeCAD/releases
Thanks.
Re: FreeCAD-AppImages do not run under opensuse Tumbleweed (invalid magic cookies on tumbleweed)
Postby Kunda1 » Tue Aug 27, 2019 5:20 pm
Updated title per @looo's suggestion
triplus
Postby triplus » Thu Sep 05, 2019 12:14 pm
I read this thread again and it is more about the FreeCAD package provided by openSUSE, and less about the AppImage. Best to report to openSUSE FreeCAD package maintainers. As for the AppImage, if anybody is interested, some fixes have just landed in FreeCAD 0.18 AppImage:
https://github.com/FreeCAD/FreeCAD/releases/tag/0.18.3
And it is expected for FreeCAD 0.19 AppImage to in general work OK:
https://github.com/FreeCAD/FreeCAD/rele ... g/0.19_pre
