drag and drop in tree view drag does not work
bernd
Postby bernd » Wed Jul 10, 2019 10:04 pm
- start FreeCAD
- open the attached document
- Drag MeshGroup001 out of FEMMeshGmsh001 and Drop it into FEMMeshGmsh
- Drop does work
- Drag does not work
- The MeshGroup001 is still a member of FEMMeshGmsh001 but it should have been moved
Is there an error in the implementation or this an intended behave?
code: https://github.com/FreeCAD/FreeCAD/blob ... #L173-L240
fem-drag-and-drop.FCStd
(200.25 KiB) Downloaded 6 times
OS: Debian GNU/Linux 10 (buster) (KDE/plasma)
Version: 0.19.17331 (Git)
Build type: Unknown
Hash: cf18161dc26267c259ac21675cb9637263bf4152
Python version: 3.7.3
Qt version: 5.11.3
Locale: German/Switzerland (de_CH)
bernd
Re: drag and drop in tree view drag does not work
Postby bernd » Wed Jul 10, 2019 10:14 pm
- it works if MeshGroup001 is draged out of FEMMeshGmsh001 into the document first and afterwards dropped into the FEMMeshGmsh
- Is there a preference or something else to move an object instead of just add it tho another ?
Site Admin
Postby wmayer » Thu Jul 11, 2019 3:39 pm
In Qt a QDropEvent provides several kind of drop-actions: https://doc.qt.io/qt-5/qdropevent.html#dropAction
When just dragging an item with the cursor then a Qt::CopyAction is done which as its name says copies an item from one group to another group.
When the type is set to Qt::MoveAction then the item is really moved from one group to the other.
A Qt::MoveAction is set when pressing the Shift key while starting the drag/drop. But I don't know where this behaviour is implemented -- I assume it's Qt but don't know for sure.
Site Admin
Postby wmayer » Thu Jul 11, 2019 4:03 pm
I have created a QTreeWidget inside QtDesigner and enabled its acceptDrops property and set dragDropMode to DragDrop.
Now when dragging items around it copies them and when pressing the Shift key the items are moved. So, the behaviour is done by Qt.
However, there is also the property defaultDropAction that can be set to MoveAction and then by default items are moved when dragging/dropping them and you have to press the Ctrl key to copy them.
Site Admin
Postby wmayer » Thu Jul 11, 2019 5:09 pm
git commit 747a2823e I guess MoveAction is the more intuitive behaviour.
bernd
Postby bernd » Thu Jul 11, 2019 6:51 pm
good to know and works great here
+1
