sorting helixes to make efficent path
Erich Schulz
Postby Erich Schulz » Fri Jul 12, 2019 12:06 pm
so I've just added a bunch of helix operations for my pin board project (thanks for the tips to add all the holes in one button click)
Screenshot from 2019-07-12 21-41-57.png (23.59 KiB) Viewed 308 times
the next thing is how to sort operations...
ideally some kind "travelling salesmen" algorithm would be used, (eg https://developers.google.com/optimization/routing/tsp)
but failing that the sorting or x then y, or y then z would be good...
if not a full travelling salesman algorithm, and just a simple "x then y" it would be good if the y sort alternated ascending/descending so that the mill zig-zagged down the case
(although since someone has already published the TSP code then not sure if anyone would prefer a crudely sorted algorithm)
pintable2.FCStd
(526.24 KiB) Downloaded 16 times
Russ4262
Re: sorting helixes to make efficent path
Postby Russ4262 » Fri Jul 12, 2019 3:16 pm
Simple request. Basic solution is simple. I copied (X, Y) sorting instruction from Drilling Op into the Helix Op: PR #2337 [Path] PathHelix: Add simple x,y path sorting. This will provide a simple sort automatically.
More complex sorting I will leave for another time or another dev.
Thanks for the feedback.
Russ
simple (X, Y) sort in proposed PR #2337 - same as Drilling Op
Erich Schulz
Postby Erich Schulz » Sat Jul 13, 2019 11:19 am
sounds great thanks Russ!
it doesn't look too hard to incorporate a full travelling salesperson algorithm into that function
when does that sort get implemented? is it only on the "reset" button press, or every time a geometry is added?
I wonder if anyone would ever need to set up the order in specific sequence
Russ4262
Postby Russ4262 » Sat Jul 13, 2019 2:32 pm
Morning, Mr. Schultz,
Looking at the FreeCAD repo on GitHub, it appears 0.19.17352 release builds are being created and posted today for users to download. Checking the commit history, the basic sort presented in PR#2337 is probably not included. It will be in the next nightly build that admin releases - probably a couple days to a week depending upon commit volume and other factors.
... is it only on the "reset" button press, or every time a geometry is added?
I'm not familiar with the traveling salesperson algorithm, but I am familiar with the idea - shortest, most efficient route to hit all towns on the list. At the moment, I don't think path sorting more than simple (X, Y) is a top focus for devs at the moment. The ability for the user to custom group base geometry features in many of the path operations, the ability to create multiple operations easily, and the fact that operations can quickly be reordered allows for a reasonable amount of path sorting - even if it means a little more work for the user. For these reasons, and perhaps others, I don't see devs doing much in the short-term with more complex sorting algorithm integration.
As for the basic sort, it is applied automatically anytime the operation as a whole is changed and recomputed.
Make sure your doorbell is working so you'll hear the delivery man with your Mach3.
Have a great day.
Russ
bill
Postby bill » Sat Jul 13, 2019 3:03 pm
Sounds like you guys are getting things "Sorted Out" :lol: !
Time for a Cupper/or Mugger!
Woolshed still in operation?
Surfer's Paradise Grand Prix still happening or has it been moved?
And most of all; remember to Dodge, duck, dip, dive and dodge (movie: Dodgeball reference) from those Lorikeets!
