Pocket outside pad boundaries
pmarches
Postby pmarches » Sat Jul 13, 2019 4:48 pm
Hello,
I am trying to make a pocket on a pad with a curved face. When the pocket is fully within the pad, the pocket works just fine
However, if any part of the pocket falls outside the pad (by making the pocket wider), the pocket no longer is applied properly. In the big pocket screenshot you see only a thin line on the pad where some of the pocket should have been extruded.
How can I extrude a slope from a pad, if I cannot make the pocket exactly the same shape as the pad?
Thank you!
dinghy-pocket-pb.FCStd
(17.38 KiB) Downloaded 7 times
openBrain
Re: Pocket outside pad boundaries
Postby openBrain » Sat Jul 13, 2019 8:07 pm
Hi pmarches, welcome.
Your Sketch009 has a missing coincidence. You can find & fix it with Sketcher ValidateSketch.
Even with that corrected, running a geometry check with extra BOP tells that your Pad011 isn't a valid solid :
I didn't investigate deeper, but it's probably the reason why the subsequent pocket fails. ;)
bejant
Postby bejant » Sun Jul 14, 2019 10:45 am
There's a seam in the yellow face I've pre-selected in the image below.
I don't think a seam should be there, and also suspect that it is where the problem is located. If you create a Periodic B-Spline in Sketcher and Close it with a right-mouse button click, you won't get a seam.
GlouGlou
Postby GlouGlou » Sun Jul 14, 2019 12:50 pm
Maybe a bug? :roll:
But by making a half hull, it's could be help you.
halfdinghy.FCStd
(34.07 KiB) Not downloaded yet
