Ticket #4059 - Tooltips for Gui::QuantitySpinBox not showing
mlampert
Postby mlampert » Mon Jul 15, 2019 3:30 am
Just noticed that none of the tooltips are showing up anymore, instead when hovering over the field the value, or expression of the field gets displayed.
Anybody else seeing this or is there something I should for them to work again?
Reason: Added ticket number to thread title
Syres
Re: Tooltips for Gui::QuantitySpinBox not showing
Postby Syres » Mon Jul 15, 2019 9:26 am
They still work using (if I've correctly understood your description):
OS: Windows 7 SP 1 (6.1)
Version: 0.19.17331 (Git)
Hash: cf18161dc26267c259ac21675cb9637263bf4152
Python version: 3.6.8
Qt version: 5.12.1
One thing I've noticed is they can be 'lazy' so you have to be patient for the first tool tip to appear as if the time for your mouse to be still is a little long but that's being over picky.
mlampert
Postby mlampert » Mon Jul 15, 2019 6:06 pm
I played around a little more and it seems it's the expression that makes the tooltip vanish.
As soon as there is an expression attached to the property the spinbox doesn't display the tooltip anymore but displays the expression. This is not a good user experience IMHO - is there a way I can get QuantitySpinBox to display the tooltip regardless of there being an expression or not?
Site Admin
Postby wmayer » Mon Jul 15, 2019 9:10 pm
Do you have a special scenario where it fails? I created a sketch + pad and set an expression to the pad length and the property editor still showed the tool tip text and not the expression.
mlampert
Postby mlampert » Mon Jul 15, 2019 10:51 pm
Interesting - if you edit the Pocket in attached file and select the "Depths" page, all 4 of those are QuantitySpinBoxes. 3 already have an expression attached and show that one instead of the tooltip. Finish Depth doesn't have an expression and does show the tooltip - however if you set an expression it shows the expression.
Totally forgot to put my info down - sorry about that:
OS: Debian GNU/Linux 10 (buster) (LXQt//usr/share/xsessions/lxqt)
Version: 0.19.17408 (Git)
Build type: Debug
Hash: 092aaf17e846b89a16c8ce9615086eeac8a49b8c
Python version: 3.7.3
Qt version: 5.11.3
box.FCStd
(14.14 KiB) Downloaded 13 times
Site Admin
Postby wmayer » Tue Jul 16, 2019 12:29 pm
Confirmed. When looking at the quantity boxes of the task panels I can confirm this behaviour but when looking in the property editor it works as expected. Feel free to open a ticket.
Re: Ticket #4059 - Tooltips for Gui::QuantitySpinBox not showing
Postby Kunda1 » Mon Sep 09, 2019 1:00 pm
