[ANSWERED]Help learning FEM
bzb.dev001
Postby bzb.dev001 » Sat Jul 20, 2019 5:19 am
I've been following the instructions of https://youtu.be/dhrynRdBOIg for learning about using FEM.
I got as far as creating a gmsh and got a error message. I'm stuck at this point. I do not know what the error message means and how to proceed to fix the issue.
Any help is appreciated.
Thanks
FreeCAD details:
OS: Ubuntu 18.04.2 LTS (LXDE/Lubuntu)
Version: 0.19.16966 (Git) AppImage
Hash: fbafd698aefeae2dbb5a711647346b9cac7794e9
Python version: 3.7.1
Qt version: 5.6.2
sample-fem.FCStd
(33.91 KiB) Downloaded 14 times
openBrain
Re: Help learning FEM
Postby openBrain » Sat Jul 20, 2019 4:02 pm
Is gmsh installed on your computer ?
Postby Kunda1 » Sat Jul 20, 2019 4:04 pm
Mod note: Moved to FEM subforum.
OP, please update your 0.19dev version it's is woefully behind (current us r17443). Especially with anything FEM related you want the most updated 0.19 version
Postby Kunda1 » Sat Jul 20, 2019 4:06 pm
The report view shows 'GMSH done' I wonder if that is hardcoded and not a conditional...in other words it will output GMSH done no matter what ?
openBrain
Postby openBrain » Sat Jul 20, 2019 4:17 pm
FEM needs extra tools that aren't install with FC.
You can run
sudo apt-get install netgen gmsh calculix-ccx
bzb.dev001
Postby bzb.dev001 » Mon Jul 22, 2019 3:49 am
I've updated my FreeCAD to ...
Version: 0.19.17445 (Git) AppImage
Hash: 741dddf25485f692596faa9b7911e2e0f5d362a3
Python version: 3.7.3
Qt version: 5.9.7
-Installed gmsh
$ gmsh --version
4.4.0
-Installed netgen
$ netgen
NETGEN-6.2-dev
Developed by Joachim Schoeberl at
2010-xxxx Vienna University of Technology
2006-2010 RWTH Aachen University
1996-2006 Johannes Kepler University Linz
Including OpenCascade geometry kernel
optfile ./ng.opt does not exist - using default values
togl-version : 2
OCC module loaded
loading ngsolve library
NGSolve-6.2.1905
Using Lapack
Including sparse direct solver UMFPACK
Running parallel using 4 thread(s)
importing NGSolve-6.2.1905
Thank you for using NGSolve
-Using the same example FreeCAD file, I'm still getting an error message when creating FEM mesh via gmsh. The error message at the task window is...
0.0: We are going to start ...
0.0: Start Gmsh ...
0.9: Gmsh had warnings ...
0.9: Error : Unable to recover the edge 376 (1/2) on curve 15 (on surface 3) Error : Unable to recover the edge 11267 (14/29) on curve 38 (on surface 5) Error : Unable to recover the edge 11280 (17/30) on curve 42 (on surface 21) Error : No elements in volume 1 Error : ------------------------------ Error : Mesh generation error summary Error : 0 warnings Error : 4 errors Error : Check the full log for details Error : ------------------------------ Warning : Unknown element type for UNV export (MSH type 15) - output file might be invalid Warning : Unknown element type for UNV export (MSH type 15) - output file might be invalid Warning : Unknown element type for UNV export (MSH type 15)
[*** comment:I removed repeated messages ***]
0.9: Gmsh done!
-The ReportView shows the following messages...
We are going to start Gmsh FEM mesh run!
Part to mesh: Name --> Fusion001, Label --> Fusion001, ShapeType --> Compound
CharacteristicLengthMax: 1e+22
CharacteristicLengthMin: 0.0
ElementOrder: 2
ElementDimension: 3
/tmp/Fusion001_Geometry.brep
/tmp/Fusion001_Mesh_TmpGmsh.unv
/tmp/shape2mesh.geo
gmsh
No Group meshing for analysis.
The Part should have a pretty new FEM mesh!
Error : 0 warnings
Error : 4 errors
bzb.dev001
Postby bzb.dev001 » Mon Jul 22, 2019 3:56 am
I tried using a different solid to perform FEM on and it seems to work albeit there was a warning message. I wonder if there could be something wrong with the original solid.
-When creating a FEM mesh gmsh, the warning message is
0.0: Start Gmsh ...
0.5: Gmsh had warnings ...
0.5: Warning : Surface mesh: worst distortion = -1.73981 (avg = 0.94883, 2 elements with jac.
0.5: Gmsh done!
-ReportView show the following messages...
Part to mesh: Name --> Body, Label --> Body, ShapeType --> Solid
ElementOrder: 2
ElementDimension: 3
/tmp/Body_Geometry.brep
/tmp/Body_Mesh_TmpGmsh.unv
/tmp/shape2mesh.geo
gmsh
Warning : Surface mesh: worst distortion = -1.73981 (avg = 0.94883, 2 elements with jac. < 0); worst gamma = 0.00357077
Warning : Volume mesh: worst distortion = -64.1264 (avg = 0.837595, 8 elements with jac. < 0)
Warning : ------------------------------
Warning : Mesh generation error summary
Warning : 2 warnings
Warning : 0 errors
Warning : Check the full log for details
sample-beam fem.FCStd
(129.28 KiB) Downloaded 15 times
thschrader
Postby thschrader » Mon Jul 22, 2019 3:27 pm
For me it works.
Try to use a finer mesh.
Here: max Element size 1 mm.
openBrain
Postby openBrain » Mon Jul 22, 2019 5:35 pm
Definitely there are. I took your OP example file and ran a geometry check with BOP enabled. There are some errors that probably lead to your final problem. They come from your array that has intersecting shape.
The good news is that this isn't a big issue, and everything get solved by setting "Refine = true" in the object properties.
Then gmsh still complains (AFAIK it always complains :lol: ) but it generates a good mesh that can seamlessly be used for FEM analysis.
Eg. below I fixed the feet and pushed 50 kg it's too much :D ) :
I'll attach the FreeCAD file but I have to clean it so it is accepted by the forum. ;) => EDIT : I had to remove the results from the FEM analysis !
Beware that refining the shape will mostly break the existing FEM constraints and material attachment.
HTH
sample_FEM_OB.FCStd
(323.66 KiB) Downloaded 14 times
bzb.dev001
Postby bzb.dev001 » Mon Jul 22, 2019 8:55 pm
Thanks for the reply. The particular sample FreeCAD file I uploaded, in which you responded to, was a working model. It's purpose was to prove that FEM mesh by gmsh was installed ok and working ok. That's how I determined that it must've been something wrong with the solid in question. The original non-working FreeCAD model was provided at the start of this posting.
For me it works.
