inverse attributes
This forum section is only for IFC-related issues
yorik
Site Admin
inverse attributes
Postby yorik » Fri Mar 01, 2019 1:29 am
You know, something I've been thinking... This big series of if ... if ...if ... if at the beginning of IFC import, that builds many lists and dictionaries. I had done that at the very beginnings of IfcOpenShell. Now, IfcOpenShell has the "reverse" attributes specified in IFC docs implemented too. So we would be able to simplify this block a lot, no more need to build all these tables, you can, from an object get quite easily to its properties, attributes, materials, etc...
Thoughts for later!
bernd
Re: inverse attributes
Postby bernd » Sun Mar 03, 2019 8:43 pm
great! Do you have some example code?
yorik
Site Admin
Postby yorik » Wed Mar 06, 2019 5:40 pm
Not really but if you look for ex. at the bottom of http://www.buildingsmart-tech.org/ifc/I ... fcwall.htm
you can now use all the inverse attributes too. So for ex:
f = ifcopenshell.open("somefile.ifc")
wall = f[54] # let's say this is a wall
print(wall.OwnerHistory) # this worked before already
print(wall.HasOpenings) # this now works too
bernd
Postby bernd » Thu Mar 07, 2019 7:47 pm
got the point! :)
bernd
Postby bernd » Mon Jul 15, 2019 3:16 pm
https://standards.buildingsmart.org/IFC ... fcwall.htm
bernd
Postby bernd » Sun Jul 21, 2019 10:10 pm
https://forum.freecadweb.org/viewtopic. ... 22#p321124
Basically at the moment we have many for...in... loops that scan the whole IFC file contents to extract relationships. However, IFC object can inform themselves of their relationships, thanks to inverse attributes. So the idea would be to, for example, for each of the relationships dictionaries created at file opening, find each place where they are used in the code, and replace with the appropriate relationship attribute.
bernd
Postby bernd » Wed Jul 24, 2019 1:49 pm
seams the property sets are not listed in the inverse attributes. Means there is no inverse attribute in ifcslab or ifcwall which gives the property sets of this object. Seams I took a bad example to start with ... :(
hlg
Postby hlg » Wed Jul 24, 2019 4:44 pm
Indeed, there is the inverse attribute for property sets. Property Sets are related to Products via IfcRelDefines. So you can access the property sets via IfcProduct.IsDefinedBy.RelatingPropertyDefinition. In IFC2x3 You need a type check before accessing the property definition, because the relation can be of type IfcRelDefinesByProperties or IfcRelDefinesByType. In IFC4 the type check is not necessary anymore, because there is a new inverse IsTypedBy and thus IsDefinedBy is reserved exclusively for property definitions.
bernd
Postby bernd » Sat Jul 27, 2019 7:50 pm
very cool :D
get file gruen_new.ifc from here https://forum.freecadweb.org/viewtopic. ... 60#p280947
import ifcopenshell
myfile = '/home/hugo/Desktop/gruen_new.ifc'
ifcfile = ifcopenshell.open(myfile)
ifcfile.by_type("IfcColumn")[0].IsDefinedBy[0].RelatingPropertyDefinition
will give
>>> import ifcopenshell
#264=IfcPropertySet('0_dPGJz$zDLuqGzu62$ZMQ',#11,'Allplan Attributes',$,(#255,#256,#257,#258,#260,#261,#262,#263))
bernd
Postby bernd » Sat Jul 27, 2019 8:03 pm
just found something very very cool ... same ifc file
import ifcopenshell
print(ifcfile[264] == ifcfile['0_dPGJz$zDLuqGzu62$ZMQ'] == ifcfile.by_id(264))
>>> import ifcopenshell
True
AFAIK importIFC only uses ifcfile.by_id(xxx) but ifcfile[xxx] works too
