[Robot] Status of WB and Edge2Trac orientation
ascaron
Postby ascaron » Mon Jul 22, 2019 11:52 pm
my name is Maxim and I was using FC for a couple of months now.
My main field is programming in automation mainly robots and PLCs, but due to unexpected circumstances I had to start to also design our robot cells. I started with SolidWorks but... well, Richard Stallman got me. Unfortunately it's not easy finding free (as in freedom, not beer) software especially for robots and PLCs but at least for CAD design I found this great free alternative which I'm really thankful for.
Another proprietary app that I use right now is RoboDK for robot offline programming. It's a great tool with a similar philosophy (well as far as you can compare closed to open source) as FC for openness in terms of a scripting API. Compared to the Robot WB it's miles ahead but as mentioned earlier I am interested in a free solution first.
So I'd like to know what the status of the Robot WB is. It looks like there hasn't been major development for quite some time now. Is it planned to keep the WB around? Because I have some ideas I'd like to implement. My idea is making some improvements to some of the available tools first and to start using C++/Python again (it has been a while) and open source development in general. I have a mathematical background (it has also been a while) of kinematics specifically serial kinematics though the KDL library probably has all kinds of math implemented already.
To start with I'd like to implement automatic orientation of Edge2Trac objects by calculating the normal vector of edges in Z direction followed by calculating the normal vector by investigating the shapes/faces contigous to the edge. Is someone working on it already? Is it maybe already implemented and I did not find it?
wandererfan
Re: [Robot] Status of WB and Edge2Trac orientation
Postby wandererfan » Tue Jul 23, 2019 11:11 am
There was some talk about moving the Robot WB out of the core system and making it an add-on workbench, but I don't think anything became of it. AFAIK, there are no plans to remove Robot.
If you want to work on Robot, by all means go ahead. Post your plan in "Open Discussion" to get feedback from interested parties, then make your changes and submit PR(s).
If you get stuck somewhere in the development process, just post to this forum or "Python Scripting" and some one will help you.
wf
jmaustpc
Postby jmaustpc » Tue Jul 23, 2019 2:02 pm
the most likely reason for Robot WB to be removed is if it bit-rots into dysfunction and if no one works on it. It would be great if you want to work on it.
Robot WB was created before Path WB existed, I wonder how much of Path could be relevant to a robot? Surely there would be some use in using a Path in programming a robot? I don't know much about the subject. Are, or can, some or all robots be controlled with g-code or similar?
Postby Kunda1 » Tue Jul 23, 2019 3:16 pm
Interesting related links:
https://forum.freecadweb.org/viewtopic.php?f=10&t=22081 - Robot Workbench development
https://forum.freecadweb.org/viewtopic.php?f=10&t=15442 - URDF Workbench, robotics
https://forum.freecadweb.org/viewtopic.php?f=24&t=26404 - Annotations for robotics workbench (ARBench)
fosselius wrote:ping
ascaron
Postby ascaron » Tue Jul 23, 2019 3:31 pm
Alright, I will do that.
Absolutely. Robots have a wider application range than CNC machines, but machining is one of them. It would be awesome to combine both WBs to simulate the milling (and someday maybe 3D printing) process with a robot. Unfortunately robots come with a cost for their flexibilities. There are some constraints like singularities that must be avoided while milling but it would be the job of the Robot WB to bypass those and find the best configuration. Thats one of the reasons that robots have their own languages but it should be possible already to translate the path output to robots by using a respective post processor.
fosselius
Postby fosselius » Tue Jul 23, 2019 9:56 pm
As for the URDF workbench, currently its rather a SDF workbench, and I currently use pybullet rather than gazebo. but development progress is slow and sporadic. but hopefully will speed up a bit now that i am actually working on a robot project.
