Can't merge ball bearing
freecc
Postby freecc » Fri Jul 26, 2019 6:25 pm
I have created a ball bearing that I want to 3d-print. But I can't merge them. Maybe someone can help?
kullager.FCStd
(263.1 KiB) Downloaded 28 times
Re: Can't merge ball bearing
Postby chrisb » Fri Jul 26, 2019 8:27 pm
What do you mean with "merging"?
freecc
Postby freecc » Fri Jul 26, 2019 9:03 pm
the boolean operation, adding them together
Postby chrisb » Fri Jul 26, 2019 10:58 pm
We call it "Fusion" or "Union".
Your model has coplanar faces which you want to fuse. They often cause problems with boolean operations. And you have to set Fuse=true in the arrays such as Array002, if the items overlap.
papyblaise
Postby papyblaise » Sat Jul 27, 2019 7:31 am
Hello
If you "merge" all parts of thit "ball-bearing" the result ll be a compact block of material :!:
freecc
Postby freecc » Sat Jul 27, 2019 12:43 pm
Your model has coplanar faces which you want to fuse. They often cause problems with boolean operations. You have to set Fuse=true in the arrays such as Array002, if the items overlap.
thanks
Postby chrisb » Sat Jul 27, 2019 1:18 pm
Rereading my comment I'm afraid it was a bit unclear. These are two issues: Coplanar and setting the fuse property. I have corrected my post above.
