PDF inside the project
philixx88
Postby philixx88 » Mon Jul 29, 2019 7:16 am
Good morning everyone!
Is there a way in FreeCAD 0.18 (windows) to upload PDF file inside the project?
Thank you!
F
yorik
Site Admin
Re: PDF inside the project
Postby yorik » Mon Jul 29, 2019 1:57 pm
This is doable but only via python:
You can add a new FileIncluded property to any object (it must be a python-defined object - object.TypeID must be App::FeaturePython or Part::FeaturePython or any other that ends with Python) like this:
myObj.addProperty("App::PropertyFileIncluded","AttachedPdfFile")
myObj is your object, you can get the currently selected object with:
myObj  FreeCADGui.Selection.getSelection()[0]
and "AttachedPdfFile" can be anything (use the CamelCase convention). After that your object will have a new "Attached Pdf File" property, that you can set to a pdf file. That file will be embedded into the FreeCAD file.
When opening the FreeCAD file, a temporary folder is created, and inside that temporary folder, there will be a read-only version of the pdf file.
Postby Kunda1 » Mon Jul 29, 2019 2:43 pm
Is this a feature that can be requested for the BCF GSoC project ?
philixx88
Postby philixx88 » Mon Jul 29, 2019 6:19 pm
thank you, I'll try this method! :)
yorik
Site Admin
Postby yorik » Tue Jul 30, 2019 10:24 pm
There is not much to do with BCF. But in any case the feature is there already.. Not usable via the GUI, but then it would need more definition to know what should be implemented, and how, and where...
