Has Anyone successfully connected to FC thru Jupyter ?
randfb1
Postby randfb1 » Mon Jul 29, 2019 9:05 pm
If yes, could you share the procedure.
I tried using the module at:
https://github.com/looooo/jupyter_freecad_kernel
without success.
thanks
Rand
vocx
Re: Has Anyone successfully connected to FC thru Jupyter ?
Postby vocx » Mon Jul 29, 2019 10:26 pm
looo wrote: Ping
looo
Postby looo » Mon Jul 29, 2019 10:56 pm
without success.
thanks
Rand
This was only a test but as freecad uses python we do not need to write an own kernel.
Easiest way to get compatible freecad and jupyter is by use of conda-package manager. Eg.:
conda create -n freecad freecad jupyterlab
To start the freecad-gui from jupyter you can have a look here:
https://forum.freecadweb.org/viewtopic. ... 30#p257684
It's possible the commands to launch freecad are a bit different on different pöattforms. But launching freecad from jupyter-notebook worked for me on all 3 major platforms.
Postby Kunda1 » Mon Jul 29, 2019 11:34 pm
What would be the benefit of having jupyter connected to FC? Could we show FC models from within a jupyter notebook etc.. ?
looo
Postby looo » Tue Jul 30, 2019 5:45 am
What would be the benefit of having jupyter connected to FC? Could we show FC models from within a jupyer notebook etc.. ?
Not yet. Hopefully we get there at some point. There is not much 3d visualization for notebooks so far, so maybe this will need some time until something useable will be available.
The main advantages of jupyter-notebook over freecad-console is the cell-based code input (imo)
looo
Postby looo » Tue Jul 30, 2019 8:36 am
BTW.: Also auto-complete works better.
randfb1
Postby randfb1 » Tue Jul 30, 2019 2:59 pm
Thanks for your help.
I was able to access FC through Jupyter.
I entered the commands below.
After that FC started and the FreeCAD and App objects were available.
I think this could be a very powerful interface to FC.
Rand
import sys, os
os.environ["QT_API"] = "pyside"
%gui qt5
import FreeCADGui
FreeCADGui.showMainWindow()
FreeCADGui.exec_loop()
I
without success.
thanks
Rand
[/quote]
[/quote]
