What version are you using? If you are using freecad-daily (v0.19) you can use the line decorator to mark the lines invisible.71GA wrote: ↑Thu Aug 01, 2019 8:32 pmI have finished my 3D model and now I have to supply the documentation using TechDraw workbench. Workbench shows two lines that shouldn't be there (attachment - marked with a yellow marker). What kind of lines are these two lines and how do I turn them off? I supply also the screenshot of the detail of the 3D model.
Here are the details of the version:wandererfan wrote: ↑Fri Aug 02, 2019 12:43 amWhat version are you using? If you are using freecad-daily (v0.19) you can use the line decorator to mark the lines invisible.71GA wrote: ↑Thu Aug 01, 2019 8:32 pmI have finished my 3D model and now I have to supply the documentation using TechDraw workbench. Workbench shows two lines that shouldn't be there (attachment - marked with a yellow marker). What kind of lines are these two lines and how do I turn them off? I supply also the screenshot of the detail of the 3D model.
Did you have transparency turned ON? I think it might be correlated to this...dcapeletti wrote: ↑Thu Aug 01, 2019 11:12 pmHi, something similar happens to what happened to me. A few days ago I published it. https://forum.freecadweb.org/viewtopic.php?f=35&t=38118
Hi, no, it's not about transparency, it's about a projection error.71GA wrote: ↑Fri Aug 02, 2019 4:38 amDid you have transparency turned ON? I think it might be correlated to this...dcapeletti wrote: ↑Thu Aug 01, 2019 11:12 pmHi, something similar happens to what happened to me. A few days ago I published it. https://forum.freecadweb.org/viewtopic.php?f=35&t=38118
