My TechDraw templates (Slovenian) - GPL 2.0
71GA
Postby 71GA » Sat Aug 17, 2019 6:31 pm
There was a discussion where I criticized TechDraw a bit and this came up:
chrisb wrote:
Sat Aug 17, 2019 12:41 pm
2) Fix the issues yourself. As a Linux coach you should be able to. You will get here all the help we can offer, and would like to see your pull requests.
I am currently busy working on other project, but I can contribute my TechDraw templates if anyone needs them (attachment). So that I won't only criticize. That is not good I admit that.
Templates were made in Inkscape and they have smaller edge (2.5 mm) than is standard, but they make use of space quite well! The triangular marks on the edge of the drawing space show where paper needs to be folded in order to get A formats down to the A4 size. Just translate them to your own language using Google translate and Inkscape and you will have some nice templates.
I will post several posts as it is not possible to attach so many files to one post.
1st templates for companies...
A3 (L) -- freesans (italic) -- vpetje (da) -- logotip (ne) -- sestavna risba (10).svg
(96.61 KiB) Downloaded 40 times
A3 (L) -- freesans (italic) -- vpetje (da) -- logotip (ne) -- sestavna risba (5).svg
(83.13 KiB) Downloaded 30 times
A3 (L) -- freesans (italic) -- vpetje (da) -- logotip (ne) -- delavniska risba.svg
(66.03 KiB) Downloaded 30 times
A2 (L) -- freesans (italic) -- vpetje (da) -- logotip (ne) -- delavniska risba.svg
(85.89 KiB) Downloaded 30 times
A1 (L) -- freesans (italic) -- vpetje (da) -- logotip (ne) -- delavniska risba.svg
(113.5 KiB) Downloaded 33 times
71GA
Re: My TechDraw templates (Slovenian) - use as you please!
Postby 71GA » Sat Aug 17, 2019 6:33 pm
more ...
A4 (P) -- freesans (italic) -- vpetje (da) -- logotip (ne) -- sestavna risba (18).svg
(105.04 KiB) Downloaded 23 times
A4 (P) -- freesans (italic) -- vpetje (da) -- logotip (ne) -- sestavna risba (10).svg
(83.33 KiB) Downloaded 25 times
kkremitzki
Postby kkremitzki » Sat Aug 17, 2019 7:03 pm
Thanks for your contribution! Just to be sure, what license are you releasing these under? If you want it to be, for example, the same license as the FreeCAD wiki, you could use https://creativecommons.org/licenses/by/3.0/.
71GA
Postby 71GA » Sat Aug 17, 2019 8:28 pm
If I would have to choose I would say GPL 2.0.
Postby chrisb » Sun Aug 18, 2019 1:49 am
Thanks! We may think about a repository for such things, similar to Addons.
wandererfan
Postby wandererfan » Sun Aug 18, 2019 12:48 pm
I've put them here for now: https://github.com/WandererFan/FreeCADTemplates
Isn't there a problem with including GPL2 work in the FC distribution?
vocx
Postby vocx » Mon Aug 19, 2019 3:30 pm
Yes, there is.
However, perhaps 71GA should consider the license. For images, art, and things that aren't code, a GPL license doesn't really make sense, which is why kremitzki suggested Creative Commons.
71GA wrote:
Sat Aug 17, 2019 6:35 pm
ping
Are you really contributing SVG files, basically images, as GPL? Why not CC?
