conda build win 10 stopped working since Link merge
sgrogan
Re: conda build win 10 stopped working since Link merge
Postby sgrogan » Sat Oct 12, 2019 6:27 pm
UR_ wrote:
Sat Sep 14, 2019 11:33 am
That's it.
Powered by Conda! I had to "Boost_NO_BOOST_CMAKE=TRUE"
OS: Windows 7 SP 1 (6.1)
Version: 0.19.18516 (Git)
Hash: 867a09f731926bf75695e8a6f063cbc9c1033b40
Python version: 3.7.3
Qt version: 5.12.1
Syres
Postby Syres » Sun Oct 13, 2019 8:49 am
Qt version: 5.12.1
I downloaded and extracted FreeCAD_0.19.18516_x64_Conda_Py3QT5-WinVS2015.7z this morning in order to try something with Python 3.7 but unfortunately FreeCAD crashed during the load sequence. Below is the last part of the log and attached is the Debug.log file generated if it is of use:
Log: Init: Loading FreeCAD GUI
Log: Init: Running FreeCADGuiInit.py start script... done
Log: Init: Activating default workbench StartWorkbench
Log: Loading GUI of Web module... done
Log: Loading GUI of Start module... done
Log: Loading Start module... done
Log: Qt WebEngine ICU data not found at C:/Users/Chris/Miniconda3/envs/freecad-dev123/Library/resources. Trying parent directory...
Log: Qt WebEngine ICU data not found at C:/Users/Chris/Miniconda3/envs/freecad-dev123/Library. Trying application directory...
Log: Qt WebEngine ICU data not found at E:/Data/My Downloads/FreeCAD_0.19.18516_x64_Conda_Py3QT5-WinVS2015/FreeCAD_0.19.18516_x64_Conda_Py3QT5-WinVS2015/bin. Trying fallback directory... The application MAY NOT work.
Log: Installed Qt WebEngine locales directory not found at location C:/Users/Chris/Miniconda3/envs/freecad-dev123/Library/translations\qtwebengine_locales. Trying application directory...
Log: Qt WebEngine locales directory not found at location E:/Data/My Downloads/FreeCAD_0.19.18516_x64_Conda_Py3QT5-WinVS2015/FreeCAD_0.19.18516_x64_Conda_Py3QT5-WinVS2015/bin\qtwebengine_locales. Trying fallback directory... Translations MAY NOT not be correct.
debug.log
(5.15 KiB) Downloaded 20 times
sgrogan
Postby sgrogan » Sun Oct 13, 2019 1:33 pm
Should be fixed now.
Syres
Postby Syres » Sun Oct 13, 2019 2:12 pm
Sorry, but with the FreeCAD_0.19.18522_x64_Conda_Py3QT5-WinVS2015.7z download, it looks to be the same:
Log: Qt WebEngine ICU data not found at E:/Data/My Downloads/FreeCAD_0.19.18522_x64_Conda_Py3QT5-WinVS2015/FreeCAD_0.19.18522_x64_Conda_Py3QT5-WinVS2015/bin. Trying fallback directory... The application MAY NOT work.
Let me know if there's any other info you need.
sgrogan
Postby sgrogan » Mon Oct 14, 2019 10:05 pm
Your info is great.
I got rid of the hard coded paths in qt.conf and added the resorses directory.
Can you try again? Can you post the log even if it succeeds?
Syres
Postby Syres » Tue Oct 15, 2019 7:39 am
No success I'm afraid:
Log: Qt WebEngine ICU data not found at E:/Data/My Downloads/FreeCAD_0.19.18533_x64_Conda_Py3QT5-WinVS2015/FreeCAD_0.19.18533_x64_Conda_Py3QT5-WinVS2015/bin. Trying fallback directory... The application MAY NOT work.
UR_
Postby UR_ » Tue Oct 15, 2019 10:58 am
Just downloaded: FreeCAD_0.19.18533_x64_Conda_Py3QT5-WinVS2015.7z
fixed qt.conf to
[Paths]
TargetSpec = win32-msvc
HostSpec = win32-msvc
Prefix = ..
Headers = include/qt
launching FreeCAD.exe by this shortcut
Screenshot 001.png (24.15 KiB) Viewed 496 times
works fine.
Syres
Postby Syres » Tue Oct 15, 2019 11:40 am
fixed qt.conf to
[Paths]
Prefix = ..
@UR_, thanks for the workaround, I can confirm it worked so at least I can do my testing.
@sgrogan, if I just amend qt.conf to @UR_'s suggestion but keep the file structure as I prefer in E:\Data\My Downloads, I get the following at the end of the log:
Log: Installed Qt WebEngine locales directory not found at location E:/Data/My Downloads/FreeCAD_0.19.18533_x64_Conda_Py3QT5-WinVS2015/FreeCAD_0.19.18533_x64_Conda_Py3QT5-WinVS2015/translations\qtwebengine_locales. Trying application directory...
Log: Loading GUI of Part module... done
Log: Loading Sketcher module... done
Log: Loading GUI of Sketcher module... done
Log: Init: Showing main window
Log: Main window restored
Log: Show main window
Log: Toolbars restored
Log: 3Dconnexion device not attached.
Log: Init: Entering event loop
Log: Init: Processing command line files
Log: Hide main window
Log: Finish: Event loop left
Log: Destruct Gui::Application
Log: FreeCAD terminating...
Log: Saving system parameter...
Log: Saving system parameter...done
Log: Saving user parameter...
Log: Saving user parameter...done
Resulting in a GUI being displayed, preferences such as Stylesheet are correct but others such as the Start Wb aren't open as expected. Hopefully both of our feedback can assist in a fully portable package, thanks for the efforts.
sgrogan
Postby sgrogan » Tue Oct 15, 2019 9:08 pm
Thanks for the feed back, this helps a lot.
For the qt.conf, I was making similar fixes as @UR_, but then overwriting the fixes with the hardcoded paths :oops:
I think the Headers directory should not be needed as this path is not included in the bundle (it's not needed in the LP_12.1.2 version).
@Syres, is your default WB Part, maybe with a custom toolbar that adds Sketcher?
Can you try making Start the default WB? Maybe it will crash and give some good info in the log.
Syres
Postby Syres » Tue Oct 15, 2019 9:31 pm
Nope, the default Wb has been Start for months now which then switches to Sketcher after I've clicked a recent file or Create New.. as per screenshot:
Therefore that log above is with these settings.
