What is the difference between the "mesher" tools?
leoheck
Postby leoheck » Tue Aug 20, 2019 6:46 pm
I have to generate some meshes to 3d print.
I was just exporting .stl files or just importing FCStd files directly on Cura. Since Freecad 0.18.3 does not work anymore with the Cura plugin, I would like to use the Mesh Workbench for that.
I am seeing here, 3 mesher tools (standard, mefisto, and netgen). I have two questions.
1. So what is the difference between them? There is no info about that here https://www.freecadweb.org/wiki/Mesh_MeshFromShape
2. Why netgen ins not available (it is greyed out)?
Reason: Fixed typo on thread title
PrzemoF
Re: What is the difference bettwen the "mesher" tools?
Postby PrzemoF » Thu Aug 22, 2019 10:43 am
1. Search the net using !fc on duckduckgo.com
2. Maybe it's not compiled in your version of FreeCAD
UR_
Postby UR_ » Thu Aug 22, 2019 11:26 am
example:
Screenshot 004.png (76.13 KiB) Viewed 198 times
Syres
Postby Syres » Thu Aug 22, 2019 11:50 am
I use this macro (thanks to Damian Łoziński) https://github.com/dlozinski/FreeCAD-ma ... cer/slic3r , it's not yet merged into master but it can be used with Cura by modifying line 24 to reflect the Cura location e.g.
SLICER_CMD = ["E:/MyProgs/Ultimaker Cura 4.2/Cura.exe"]
line 27 to the obj format
OUTPUT_FORMAT = "obj"
and lines 72 & 74 to have Cura rather than Slic3r in the messages. The quality of the 3D prints is sufficient for me but if you're not satisfied then you will need to change line 30 for AngularDeflection and/or line 60 LinearDeflection (in mm). I've tested it successfully with 0.18.2, 0.18.3 and the Link3 merge 0.19.17803 Windows Build.
