I am really new to FreeCad and currently working on a room with a size of 5500x2500x2300mm.
Now I have two problems:
Problem 1:
If I add a dimension, I can't see the value because it's too small.
I can set the arrow size to 20mm and the font size to 100mm to see the values but I am sure there is a easier way to do it?
(Set display mode to 3D also helps but then, I don't see the arrows without setting the arrow size manually)
Problem 2:
If I now add a drawing (DIN A4) and add the body (5500x2500x2300mm) to it, I see nothing. Because the body is too big for the drawing.
If I set the scale of the view to 0,01 I see "something" in the corner...
Is there any trick to work with bodies with these sizes?
Thank you!!
