Incorrect behavior of the Label tool in the Draft workspace
doubters
Postby doubters » Thu Aug 22, 2019 9:29 pm
1. The label parameter "Display Mode" is not saved and, after opening the file, returns to "3D text"
2. Extra characters for Custom text on the working field (fixed in version 0.19)
3. When changing the "Display Mode" from "3D text" to "2D text", "Text Alignment" has to be changed several times to correctly position the inscription.
Video: https://www.freecadweb.org/tracker/file ... 5&type=bug
vocx
Re: Incorrect behavior of the Label tool in the Draft workspace
Postby vocx » Thu Aug 22, 2019 11:42 pm
Which is the FreeCAD version you are testing this with? Because reporting things against the 0.18 version isn't very helpful if it's already fixed in 0.19. The best thing to do is to test it against the latest development version. For example, Roy_043 has tested a bunch of Draft and Arch functions lately.
Roy_043 wrote:
Thu Aug 01, 2019 7:18 am
A draft label's initial Display Mode is '3D text' according to the View properties. But the text is displayed as '2D text'.
Roy_043 wrote:
Sat Aug 03, 2019 10:27 am
Editing the Custom Text property of a Draft Label does not work properly if you remove text lines.
Roy_043 wrote:
Sat Aug 03, 2019 10:30 am
Moving a Draft Label results in the Target Point being left behind. Copying a Draft Label is not possible. It would be nice if you could snap to points on the line.
Roy_043 wrote:
Sat Aug 17, 2019 12:03 pm
I have just discovered the Frame property. Changing this to Rectangle shows that the bounding box is indeed inaccurate (assuming the frame is drawn closely around the box). For labels created from left to right, as in the OP, the frame appears to be mirrored.
Another thing I noticed: The 'Text Size' property is in fact used as the line height.
Draft Label: Problem with Text Alignment
doubters
Postby doubters » Fri Aug 23, 2019 4:48 am
Paragraph 1 and 3 appear on all versions of FreeCAD. Last checked on this:
OS: Ubuntu 19.04 (ubuntu:GNOME/ubuntu)
Version: 0.19.17798 (Git) AppImage
Hash: 7e60631239109c632a8f6cca83f6e7e5502e43a1
Python version: 3.7.3
Qt version: 5.9.7
Locale: C/Default (C)
Roy_043
Postby Roy_043 » Fri Aug 23, 2019 7:27 am
I'll try to revisit some of the issues I have reported and add them to the bug tracker. After discussing them here first of course.
