Air Plane Design Workbench - discussion thread
a179308
Postby a179308 » Wed Aug 28, 2019 7:48 pm
I've have started a Air Plane Design Workbench :https://github.com/FredsFactory/FreeCAD_AirPlaneDesign . Available to install in the addon manager, Air Plane Design Workbench V0.1 and V0.2 can create a wings based on panel and profil.
Please don't use the V0.1 it was a first draft, based on sheet with which I designed the wing of my ASK13 (https://fredsfactory.fr).
The approach on the V0.2 is completely different and integrate parametric objects based on a dedicated UI.
You can use this discussion thread to interact with me.
Hoping this can be of some utility for FC users.
Fred
Capture d’écran 2019-08-15 à 22.18.48.png (1014.47 KiB) Viewed 2986 times
Capture d’écran 2019-08-15 à 22.19.09.png (636.17 KiB) Viewed 2986 times
Re: Air PLane Design Workbench - discussion thread
Postby Kunda1 » Wed Aug 28, 2019 11:05 pm
Awesome. Can you make a short video on how you use it ?
adrianinsaval
Postby adrianinsaval » Thu Aug 29, 2019 2:01 am
Nice! Will be testing altought the french is a little confusing.
a179308
Re: Air Plane Design Workbench - discussion thread
Postby a179308 » Thu Aug 29, 2019 5:13 am
Hello
wait a few days, I will translate the ui and produce a little video.
Fred
miniellipse
Postby miniellipse » Thu Aug 29, 2019 9:03 pm
Nice. Very useful. Thank you. Looking forward to a video on how to use.
Zolko
Postby Zolko » Mon Oct 07, 2019 12:24 pm
Does this allow to specify wing planform, airfoil sections, taper, dihedral ... and get the contour of the ribs at any location ? And then, may-be, give the GRBL file to cut the ribs ? And does this allow to calculate the GRBL path for a 4-axis foam-cutter ?
I'd be VERY interested in this, and also in helping to improve it.
a179308
Postby a179308 » Thu Oct 10, 2019 6:32 pm
It's my goal :D
At this stage you can create a parametric rib based on dat file. You can also create a wing composed by panels, each panel can be oriented.
To produce a GCODE you can use the path workbench, but you will limited to produce Gcode in 2.5D
Next step is to cute all ribs, and spend some time to translate the UX and produce a short video.
if you want to contribute do not hesitate ...
Fred
pl7i92LCNC
Postby pl7i92LCNC » Sat Oct 12, 2019 12:55 pm
will it take NACA profiles
as the Python addon for Linuxcnc XYUV Gcode does
http://wiki.linuxcnc.org/cgi-bin/wiki.p ... _EDM_Style
a179308
Postby a179308 » Sat Oct 12, 2019 5:48 pm
Good idea I will analyse the code.
Fréd
a179308
Postby a179308 » Sun Oct 20, 2019 8:55 am
thanks for you suggestion. I integrate a NACA 4 and 5 digits in the workbench.
Capture d’écran 2019-10-20 à 10.41.37.png (155.66 KiB) Viewed 1831 times
After creation you can change the NACA profil/Number of points and choord or switch to a DAT file.
Capture d’écran 2019-10-20 à 10.42.06.png (122.5 KiB) Viewed 1831 times
The result
Capture d’écran 2019-10-20 à 10.41.50.png (42.15 KiB) Viewed 1829 times
Enjoy.
Frédéric
