Air Plane Design Workbench - discussion thread
a179308
Re: Air Plane Design Workbench - discussion thread
Postby a179308 » Mon Oct 28, 2019 5:21 am
adrianinsaval wrote:
Mon Oct 28, 2019 2:52 am
pl7i92LCNC wrote:
HI! I've made a Pull Request implementing the usage of BSplines, please review! Currently, there is no GUI to choose to use either BSpline or lines since I don't really know how to do that, please make one if you can.
To anyone interested, head to my branch if you wanna test.
Thanks!
very good job, I tested the modification and merge is done :D. I will integrate the option in the gui.
Thanks a lot
Frédéric
a179308
Postby a179308 » Mon Oct 28, 2019 5:10 pm
Thanks!
Thanks a lot
Frédéric
now the GUI integrate a checkbox to use or not a BSpline.
Capture d’écran 2019-10-28 à 18.05.32.png (875.12 KiB) Viewed 1218 times
To finalize the job, I integrate useBSpline as a property of a Rib, so you change directly the value and the rib updates automatically.
Capture d’écran 2019-10-28 à 18.05.45.png (93.36 KiB) Viewed 1218 times
Enjoy
Frédéric
adrianinsaval
Postby adrianinsaval » Mon Oct 28, 2019 6:55 pm
Excellent! That is exactly what I wanted. Thanks!
PS: gotta love the checkbox name :lol:
 <widget class="QCheckBox" name="kingOfLines">
a179308
Postby a179308 » Mon Dec 30, 2019 8:53 am
Hello
some news from Air Plane Design Workbench :
-integration of rib preview when you import DAT file or generate a NACA profil,
-visualisation of the coordinates of the profil directly in the UI
-add a Geometry properties at the Rib object to store coordinates. (in freecad console type : "FreeCAD.ActiveDocument.wrib.Geometry")
-start to integrate ability to translate workbench (I'm newbie on that process !)
enjoy and Merry Christmas and happy new year !
Fred
Capture d’écran 2019-12-30 à 09.43.45.png (997.64 KiB) Viewed 865 times
Capture d’écran 2019-12-30 à 09.43.15.png (1008.94 KiB) Viewed 865 times
Capture d’écran 2019-12-30 à 09.52.15.png (930.64 KiB) Viewed 865 times
Zolko
Postby Zolko » Mon Dec 30, 2019 7:40 pm
pl7i92LCNC wrote:
Fri Oct 25, 2019 5:42 pm
now hotwire Foam cutter. profile XY UV shoudt be considert to bring a good gcode to the mashine from the WB not over path
I agree. Apart from wire-cutting foam cores for wings, what would be the purpose of this workbench ? Yes, OK, you could also cut — CNC or laser — all the ribs, but then you need some way to customize the ribs, to place servos, cable pass-throughts, connections ... all the while keeping the parametric aspect of the problem.
Also, how does this behave with airfoils from different families (Eppler, Selig, Hepperle, NACA...) ?
I'm sorry to say it so bluntly, but importing a bunch of X-Y points into FreeCAD is not enough to make a useful workbench.
a179308
Postby a179308 » Mon Dec 30, 2019 8:56 pm
Thank you for your comment, I agree that the workbench at this stage is not enough to make a useful workbench, but after a first try on my ASK13 (some pictures below), I think that the foundation of such workshop is to properly manage ribs in parametric form.
After that first step I will work on the wing with two approach :
- produce the wing envelope and make cuts to generate all the ribs, the first step of this method is implemented, and you can generate the wing, change the profil of ribs if you want and view the result. The next step is to be able to make a customization in order to integrate the elements of a wing like the servos, the wing key, the lightening of the ribs, etc ...
- produce directly all the ribs
Finally the idea of ​​communicating at this stage of development is to collect the needs / opinions of the greatest number and to orient developments towards the most useful functions.
be free to go beyond doubts and express your desires and we will see if it is feasible or not ...
Fred
Capture d’écran 2018-12-09 à 21.44.19.png (465.81 KiB) Viewed 783 times
Capture d’écran 2018-12-27 à 16.57.20.png (165.9 KiB) Viewed 783 times
miniellipse
Postby miniellipse » Mon Dec 30, 2019 9:32 pm
Fred, This is very useful. Your work is appreciated. If possible, would you mind sharing just a small section (red circle) of your wing example so I can figure out how best to do this for myself?
a179308
Postby a179308 » Tue Dec 31, 2019 5:11 pm
Download and enjoy...I will explain in detail the process in 2020...
Fred
Capture d’écran 2019-12-31 à 17.40.42_light.jpg (131.98 KiB) Viewed 712 times
Capture d’écran 2019-12-31 à 17.41.11_light.jpg (136.31 KiB) Viewed 712 times
Capture d’écran 2019-12-31 à 17.42.06_light.jpg (154.81 KiB) Viewed 712 times
wing.FCStd
(985.6 KiB) Downloaded 31 times
miniellipse
Postby miniellipse » Tue Dec 31, 2019 7:03 pm
Fred
:D This will keep me busy for a while. Thanks.
Will_C
Postby Will_C » Sun Jan 05, 2020 11:58 am
Hi Fred,
I would have two questions regarding your WB.
1) What is the intent of the property "Rib Profil" which i circled in the attached Picture?
I can change the profile by typing in a new number in the section "Naca Profil".
Is Rib Profil only necessary if I want to use a DAT file?
question ribprofile.JPG (27.29 KiB) Viewed 608 times
2) Is it possible to select and/or attach the rib geometry to a vertex?
When I create a rib it just appears at a random point and I didn't find a way to set the origin during creation.
It would be helpful if I could fix the leading edge of the rib to a parametric vertex.
BR,
Will
