Feature Hole improvements
JulianStirling
Postby JulianStirling » Thu Sep 05, 2019 7:15 pm
I am hoping to use some spare time to fix some issues I have with the Feature Hole tool. This is my first time actually developing rather than using FreeCAD so I want to discuss my plans, and confirm a couple of things.
Problems I want to address:
1. UI sometimes has dead space next to things you cant read
2. Lots of the screws have counterbore/clearance values that are not standard
3. Cannot set thread percentage (important so that an exported STEP has the correct drill size)
4. Tolerance class is in UI but appears unused. Personally I would remove thread class here. It seems that it is something for the technical drawing?
5. Weird updating behaviour (Sorry to not be more specific, I just know that at times the model doesn't seem to update when the settings do, I haven't pinned it down yet)
6. No way to add in other screw definitions, only hard coded ones are available
Things that confuse me:
1. There seems to be two sets of source code, one in Python one in C++. I think only the C++ code is in use?
2. There seems to be commented out code to trying to actually model the thread. This seems like a bad idea, it is not normal for CAD to model threaded holes as it is a lot of overhead for very little gain.
My plan (maybe not in this order)
1. Play with UI file
2. Make and class/struct for each which can contain all of their dimensions for things like clearance holes and counterbores etc. (similar to standards.py in the FeatureHole folder)
3/4. Change the Tolerance class into a thread percentage option (Probably be good to have 50%, 75% and custom in a drop-down?)
5. Nail down what is stopping things update
6. Make a way to load in extra screw definitions.
Does this seem like a sensible way forward?
RatonLaveur
Re: Feature Hole improvements
Postby RatonLaveur » Thu Sep 05, 2019 7:41 pm
Awesome sir!
Incorrect counterbore depth has been a show stopper for me.
There's also a bug in there where if you select an iso thread then go back to a default/custom hole definition the tool returns a Thread Out of Range error all the time.
Some tools also are inaccessible or buggy when generating a custom def.
Postby chrisb » Thu Sep 05, 2019 8:42 pm
There is somewhere a topic adressing 6. AFAICR the idea was to use a file similar to the tools in Path workbench.
Concerning2: Have a look at Fasteners. In these times of 3D printing it is sometimes desired to print a thread. So it would be good to be able to switch the representation.
eivindkvedalen
Postby eivindkvedalen » Fri Sep 06, 2019 7:02 pm
I did the C++ implementation, please see my comments below.
1. UI sometimes has dead space next to things you cant readScreenshot_2019-09-05_19-21-14.png
This is probably a bug in the size hint implementation for the spin box. It might not consider the space take by the f(x) icon.
All values in the tables have been found in various public available tables, if I remember correctly. It might be that they are not very much used, though.
I think this is a calculated value, based on thread standard, so the actual hole in the model should be the correct drill bit size.
The intention was to provide this information to a technical drawing module.
The dependencies between the different parts were hard to get right. Please file a bug report if you can pin it down.
This is a drawback yes. I decided to go with predefined values, because some also require some calculations. It might be that these can all be precalculated, but the table sizes might explode in size if one value depends on two or more other values. I haven't checked that.
Only the C++ version is used now.
The intention was to provide this for creating models for 3D printing, as it is perfectly fine to print working threads.
2 and 6 can be added together. If you find a way to have an external representation, there is no need to keep some standard in the code.
Feel free to ask me questions if you dive into this, although my response time may be long now due to other obligations.
Eivind
eivindkvedalen
Postby eivindkvedalen » Fri Sep 06, 2019 7:04 pm
Awesome sir!
Please file a bug report where you describe in detail how to recreate your problems.
Eivind
RatonLaveur
Postby RatonLaveur » Tue Sep 10, 2019 9:13 am
I'm not yet adept at bug reporting, I'm sorry for that. I can as a stopgap explain my qualm:
1. Create new file
2. Select PartDesign WB
3. Create Body
4. Create a sketch that you pad
5. Create a circular sketch (diameter 2 mm) on that pad
6. Use the Hole tool
7. Select Profile "ISO metric coarse profile" /other types of ISO profiles work
8. Tick "threaded"
9. Select Size "M2"
10. Go back to Profile and select "none"
11. Report View says "Unhandled Base::Exception caught in GUIApplication::notify.
The error message is: Thread size out of range"
Every time.
efyx
Postby efyx » Tue Sep 10, 2019 10:17 am
Why not points? Circles are two times more clicks.
eivindkvedalen
Postby eivindkvedalen » Tue Sep 10, 2019 5:48 pm
Vertices are not exported to the shape, so they can't be used. See https://forum.freecadweb.org/viewtopic. ... es#p154363
Eivind
JulianStirling
Postby JulianStirling » Sun Sep 15, 2019 6:51 pm
Hi Evind,
Thanks for replying. I take your point about printing threads. And the tolerance class (though I would have "unspecified" as the default option, as speccing tolerances where they are not needed pushes prices up.)
I think for thread percentages you misunderstood me when you said it was calculated. My point is that if I am tapping aluminium I will drill a smaller hole than if I am tapping steel or copper. Steel or copper I will drill a hole for a 50% thread engagement, for aluminium I will drill one for 75% engagement. In other situations other percentages are needed. The formula you have used is for 75% engagement.
I will play with how to best define screws in the code. I think something akin to a Python dictionary would be best, then you could have some standard ones and others defined by YAML. To be honest I don't really understand how the C++ and Python communicate in FreeCAD, is there a way to access a python class from C++ in FreeCAD? Or a good article explaining how the communicate?
Once this is done we should actually populate all the counterbore/countersink fields etc with values from DIN/ISO/ANSI standards and link to the standard so people know which standards have been implemented. This way it is clear what is being used.
RatonLaveur
Postby RatonLaveur » Fri Oct 11, 2019 1:06 pm
I'd like to say today that I am really grateful for the hole tool in Freecad. I generally don't use it because it's "still not perfect" but it's clearly getting there. Today i needed to produce a prototype using an online prototyping service and thanks to the ISO definitions in FreeCAD the online tool was able to recognize every threaded hole from normal holes.
Hence I'm sure my prototype will come out fine. So thanks for that!
